hd decrypter error
    hd decrypter error
    at the end of the process a pop up box shows up saying "failed to burn dvd. do you want to burn again?"
    weird question when i am only trying to decrypt, what am i missing?
    thx in advance for your help!
    Hi rob74
    If you are using the free HD Decrypter when you receive this message, what are you selecting for your Target ...optical drive or folder.
    CBR929
      folder selected on hard drive for target
      thanks for your response...it has a folder selected on a hard drive as "target".
        Hi rob74
        Thats strange, I have no way of testing this since I have lifetime for products.
        What option are you using ex: Full Disc- Main Movie, and can you still use the folder that is saved ?
        I could always uninstall Fab then reinstall and some how advance my computer time ahead 30 days to test this
        Just kidding
        It may be a minor bug I don't know.
        CBR929
          main movie selected
          yes, main movie selected...i will see if the folder is accessible after it downloads to the nas.
          thx for your help!
            thx for your help!
            Hi rob74
            If that fails try Full Disc, if using the free HD Decrypter you will no longer be able to compress or burn to disc, full disc only.
            CBR929
              Hi rob74
              CBR929
              Main Movie should still work with HD Decryptor, not just Full Disc. However, compression will not. Make sure to select DVD9 as the output size.
