8.0.9.8 - minimising
    When I click on the minimise button the DVDFab window shrinks slightly and moves into the top left corner of the desktop.
    Anyone else have this problem?
    Pete
    Win 7.
    Disappears as an icon in the message field in the lower right corner. Looks right to me.
      That's the bluetooth icon you're pointing to!
      It only seems to do it when a disc is loaded otherwise it minimises correctly.
      I'm using it on Windows 7 x64 Ultimate.
      Pete
        Only used that picture to show where it disappeared to.
        Same OS here.
          Even with a Blu-ray loaded, the monkey turns up where it should be.
          You have some skin installed/used for Windows?
            Weird, nope, no skins or themes installed, basic Win 7 pro.
            Pete
              Pete
              Latest driver version for the graphic card?
