Best DVD Burner for DVDFAB
    Optical Drives Best DVD Burner for DVDFAB
    I have an LG GSA-H73N which is almost at the end of the road.
    I need to buy a new DVD burner, and since DVDFAB is my favorite program I figured asking the advice of DVDFAB gurus be a good idea.
    Which burner works best with DVDFAB please advice.
    Thanks in advance.
    Thanks in advance.
    The question is which burner will work best with the media you plan on using.
    Some burners do not work well with Sony media others do.
    Do some research on burners and media.
    You will get dozens of different opinions here depending on each members pet burner and favorite blank media.
      I have been using the MEMOREX 8.5GB 32025732 forever, and even with a lousy burner like LG GSA-H73N had LESS than a handfull of coasters.
      Thanks for the reply
        You may also want to consider a Blu-ray burner, prices are well below the $100 mark now.
        Just my two cents worth...
          Any brand in particular?
            I use a Pioneer BDR-206 in my main computer and never had a coaster.
            The LG drives are cheaper, I've a GGW-H20L in my second computer for two years now with no issues.
            Newegg.com always has some good deals, they have an LG WH12LS30 right now for $84.99.
              Hi Fener
              I would stay away from Liteon at the moment, not that they are not good!!!
              The reason I am saying this is that they do not support binding nonce, which I believe is required if you want to make a protected disc which has Cinavia protection on it.
              CBR929
