Intel Quick Sync..
    Intel Quick Sync..
    I have an H67 sandy bridge motherboard and GeForce GTS 450 video card, also installed is Lucidlogix VIRTU. I have Quick Sync set as the A/V codec on x264.
    In this configuration on a main movie re-code DVDfab keeps hanging with the progress bar not moving for long periods of time. I then have to end the program through task manager and start again.
    I realise that you have just added Quick Sync support so there are bugs to work out, hopefully this will get fixed at some point.
    Thanks,
    Marty.
    Figured this out, you need to add DVDfab to the 'Games' tab in the VIRTU control panel.
    This tab isn't only for games, it's for programs too.
    DVDfab is fine now and using Quick Sync correctly.
      What is the VIRTU control panel?
        Thanks for letting us know VIRTU works with DVDFab
        http://www.dvdfab.cn
