Updated to DVDFab 8 QT. Went to check that it will still use my graphics card for processing acceleration.
NVIDIA GeForce GT 230M
CUDA Driver Version: 4.0
CUDA Capability revision number: 1.2
I had just updated my NVIDIA graphic card driver last week, so it should be current.
The new DVDFab does not see the CUDA driver/card; says:
"CUDA H.264 decoder cannot be supported by your graphics card"
Is this new? Is this bad?![EEK!](https://forum.dvdfab.cn/core/images/smilies/eek.png)
Will cross my finger and try software only, but it used to use the CUDA in the NVIDIA graphic card in the last version.
Thanks all.
Thanks all.
