DVD Fab True grit error
    I saw the posts about downloading DVDFAB 8.0.9.7, and when i tried to download it, it downloaded version 8.0.9.9, so i tried to copy true grit with it and it did the same thing as version 8.0.8.5.
    what do i do now? is there a certain Title that i need to click on?
    it defaults to title 4.
    please help me with this
    thanks
    First do not hijack other members threads with your request for help start your own.
    Second download V8100 from the link below.
    If you still have problems post your logs.
      sorry
      i didn't know, just thought i'd continue on the one that was similar to my issues.
        Not the same problem and a 2 week old thread where the problem had been solved.
        Try V 8100
        and post your logs if you have a problem.
          logs
          ok, i only have one question, how do i get to the logs to copy and post them?
          I'm kinda new at this.
          thanks
            thanks
            See attachment below.
            If you are not using Imgburn then ignore that attachment but copy/paste the others
              Errors
              I downloaded v 8.1.0.0. like you asked and it did the same thing, doesn't start, fast fwd a little and it plays for like 30 seconds, then shuts down to a black screen.
              here are the logs you asked for:
              2011-06-17 22:46:08 ---- ******************** Log session stop 17-Jun 22:46:08.183 PID 5876********************
              2011-06-17 22:23:04 Info Current Drive selected : 1:0:0 - hp CDDVDW TS-L633N 0300 [F] (Ide)
              2011-06-17 22:23:04 Info Using Advanced SPTI interface
              2011-06-17 22:23:04 Info System default language : English (United States)
              2011-06-17 22:23:04 Info User default language : English (United States)
              2011-06-17 22:23:04 Info DLL Version : 4.0.19.487
              2011-06-17 22:23:04 Info DLL : C:\Program Files (x86)\DVDFab 8 Qt\vso_hwe.dll
              2011-06-17 22:23:04 Info Version : 8, 1, 0, 0
              2011-06-17 22:23:04 Info ExeName : C:\Program Files (x86)\DVDFab 8 Qt\DVDFab.exe
              2011-06-17 22:23:04 Info OS : Microsoft Windows 7 Home Premium (Build 7601: Service Pack 1)
              2011-06-17 22:23:04 ---- ******************** Log session start 17-Jun 22:23:04.300 PID 5876********************
              DVDFab 8.1.0.0 (2011/06/17 22:22:38)
              0m 01.59s: option dvd2dvd 0 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2mobile 1 filemover 1
              0m 01.60s: Qt Translator file load success
              1m 22.85s: detected dvd
              1m 22.89s: drive F
              1m 22.89s: dvd type 1
              1m 22.89s: volume label TRUE_GRIT
              1m 23.33s: got copyright 1 f6
              1m 23.78s: got udf/iso
              1m 26.93s: got discinfo
              1m 26.98s: pathplayer disabled 0
              1m 29.87s: got dvdinfo
              1m 29.87s: opened dvd
              15m 02.12s: detected dvd
              15m 02.20s: drive F
              15m 02.37s: dvd type 0
              15m 02.37s: volume label
              hopefully this will help
                1m 26.98s: pathplayer 0disabled
                Make sure PathPlayer is set to "Always Enable".
                  true grit
                  ok, enabled pathplayer and it chose title 18 instead of title 4. i will let you know if it works this time.
                  thanks
                    true grit
                    now it tells me my 4.7 gb disc is not big enough for the title that pathplayer enabled selected.
                    is there anyway to shrink the files to fit on a 4.7gb disc?
                      Yeah,
                      1. Check that you have DVD5 selected as the target
                      2. Make sure that the setting for DVD65 is 4300 in the "Settings"
                      You will not be able to do this with a FREE version that has run out of the 30 day trial.
                      Hope this helps.
                        More attachments.
                          Thanks G...
                          Sorry but I can't be bothered doing that anymore!!
                            option dvd2dvd 0
                            Looks to me as a no go.
                              Originally posted by GregiBoy View Post
                              Thanks G...
                              The attachments save a lot of time.
                              The next question from any newbe is- "How do I do that or Where is that"
