Hope this is in the correct forum, if not please forgive me. I would just like to know how did you burn star trek to single layer disck with imgburn? I only copied main movie and it says file to large needs double layer disk. do i need to change a setting for this, if so, which ones?
Compression problems
Originally posted by pomonalover View Posti used main movie? does it matter because i have another movie done full movie and just got the same message needs dl disk
With the bought version you can compress it to fit a single layer disc, with the free version you can not.
You can use DvdShrink with the free version to get it to the single layer size.
Removal of new protections may not be available yet in the free version of DVDFab (HD Decrypter)
Help Us Help You :
Troy's excellent tutorial on Setting up ImgBurn with DVDFab :
I use Taiyo Yuden and Verbatim media mainly.
Trying Falcon D/L media
I use ImgBurn as my main burning engine
Free Media Player VLC
