first Blu ray copy
    first Blu ray copy
    I made my first blu ray copy of skyline and every 15 to 20 min`s in the top left corner dvdfad.com pop up is this normal?
    Also do you always have to be connected to the internet to backup your
    blu-ray dvds when using dvdfab bluray copy?
    Hi tommyboy714,
    It is normal if you are still evaluating DVDFab, you won't see it with a registered version.
    Yes, to break the AACS and BD+ copy protections, Blu-ray Copy needs to connect its server, which calls for a live internet.
