Problems with decypting after reinstall
    I recently got a virus in my computer and had to recover the whole system. After saving the dvd fab and running my recovery cd, I went to reload dvd fab. Istarted with 8.0.8.5. I had to get a new license key and I did. After trying to make a backup of one of my old dvd's (and also a newer release ) the message that it did'nt copy was given. I also tryed this with 8.1.0.0 QT with the same result. It looks like everything is running great right up to the burning portion. The message also says the problem is task_2failed= 111. Is there something else I need to download? I have had DVD Fab for probably 5 years including all the updates. Can someone help me.
    Hi virgil
    The error you are receiving is 111 HWS_DEVICEBUSY 11 // Device is busy please make sure that you have any program that uses an auto play feature when disc is inserted turned off.
    If still having problems post your logs the default location is:
    Please use attachment button and attach your most recent, Internal and Burn log(s) and post right here.
    CBR929
    EDIT: You may consider using ImgBurn as your burn engine, it is "free", you will find a tutorial on setting it up with Fab with the link in my signature.
      Burning problems
      Reading your post it would appear that you are trying to do the whole back up in one. May i suggest that you back up to the hard drive first and then as CBR929 suggests use Image Burn as your burning program.
