Nvidia GeForce FX 5200 Upgrade
    Other Hardware Nvidia GeForce FX 5200 Upgrade
    I need to upgrade my graphics card to one that will work on my old system and the QT versions without using the fabplay fix. I am not into BR or a gammer and need a step up from the FX5200 to a medium card without a fan
    My System is (old) and complete upgrade is out of the question at this time
    XP-SP3
    ASUS MB P4P 800 Deluxe
    P4 2.80 GHz
    2.81 GHz 1.00 GB Ram
    PSU 350 Watts
    So if anybody has an old system and it works with the QT versions what graphics card do you use or can anybody recommend one (Tom or Paul ?)
    Thanks in advance
    JIm
    Paid Not To Work
    US Navy Retired ( 20 Years )
    Proudly Served On
    USS Coral Sea CVA-43 (VF-154) / USS Oriskany CVA-34 (VFP-63) / USS Ranger CVA-61 (VF-121)
    6 trips to the Gulf Of Tonkin
    Just ordered the GeForce 6200, hope that will work
    Paid Not To Work
    Proudly Served On
      It works great with 8.0.8.5 and 8.1.1.2 without having to use the fabplay yeah
      Paid Not To Work
      Proudly Served On
