Super New Graphics Card - Settings?
    New graphics card (EVGA GTX550), uprated PSU - All looks good, DVD Fab (V 8112) working well. Approx conversion speeds when doing a BD-PS3 rip
    1) AV Codecs set to Software Only --- 25 fps (no real difference or improvement from the old graphics card)
    2) AV Codecs set to CUDA + Software -- 45 fps which is much better than the old one
    3) AV Codecs set to CUDA + Software + Lightning -- 45 fps which is about the same as 2 above
    Please - any guidance on the best settings for the AV Codecs with this new graphics card?
    2011-08-11 11:15:26 ---- **** Log session stop 11-Aug 11:15:26.928 PID 256 ******
    2011-08-11 11:03:17 Info Current Drive selected : 1:0:0 - HL-DT-ST BDDVDRW CH10LS20 1.00 [E] (Ide)
    2011-08-11 11:03:17 Info Using Advanced SPTI interface
    2011-08-11 11:03:17 Info System default language : English (United States)
    2011-08-11 11:03:17 Info User default language : English (Canada)
    2011-08-11 11:03:17 Info DLL Version : 4.0.20.488
    2011-08-11 11:03:17 Info DLL : C:\Program Files (x86)\DVDFab 8 Qt\vso_hwe.dll
    2011-08-11 11:03:17 Info Version : 8, 1, 1, 2
    2011-08-11 11:03:17 Info ExeName : C:\Program Files (x86)\DVDFab 8 Qt\DVDFab.exe
    2011-08-11 11:03:17 Info OS : Microsoft Windows 7 Professional (Build 7601: Service Pack 1)
    2011-08-11 11:03:17 ---- ***** Log session start 11-Aug 11:03:17.361 PID 2564*****
    DVDFab 8.1.1.2 (2011/08/11 10:18:45)
    0m 05.63s: option dvd2dvd 0 dvd2mobile 1 bluray2bluray 0 bd2mobile 1 bd23d 1 bd2dvd 1 file2mobile 1 filemover 1
    0m 05.66s: Qt Translator file load success
    0m 14.57s: detected blu-ray
    0m 14.57s: drive E
    0m 14.57s: blu-ray type 1
    0m 14.57s: volume label GLADIATOR_D1
    0m 14.78s: aacs 1 bd+ 0
    0m 16.95s: got discinfo
    0m 17.23s: got bdmv
    0m 17.23s: Vendor: HL-DT-ST
    0m 17.23s: Product: BDDVDRW CH10LS20
    0m 17.23s: Revision: 1.00
    0m 17.23s: Vendor specific: 4
    0m 17.23s: AACS version: 1
    0m 17.23s: Number of concurrent AGIDs: 1
    0m 17.23s: Supports bus encryption: NO
    0m 17.23s: Supports binding nonce generation: YES
    0m 17.23s: Supports Hybrid discs: YES
    0m 17.23s: got agid 0
    0m 17.27s: sent host cert chal
    0m 17.27s: got drive cert chal
    0m 17.27s: BEC 0
    0m 17.27s: DRIVE_VENDOR 0x0116
    0m 17.30s: got drive key
    0m 18.09s: got host key signature
    0m 18.11s: verified drive signature
    0m 18.11s: verified host signature
    0m 18.14s: sent host signature and key point
    0m 18.14s: got bus key
    0m 18.15s: got agid 0
    0m 18.17s: sent host cert chal
    0m 18.17s: got drive cert chal
    0m 18.17s: BEC 0
    0m 18.17s: DRIVE_VENDOR 0x0116
    0m 18.20s: got drive key
    0m 18.20s: got host key signature
    0m 18.22s: verified drive signature
    0m 18.22s: verified host signature
    0m 18.25s: sent host signature and key point
    0m 18.25s: got bus key
    0m 18.25s: got volume id
    0m 18.25s: got volume id mac
    0m 18.25s: volume id is correct
    0m 18.25s: got vid
    0m 18.34s: blu-ray 262244E8C4747B200635F97424777927AC72D43F
    0m 18.84s: cert BEE=0x00 same
    0m 18.84s: got vuk
    0m 18.84s: got unit key 7
    1m 03.25s: got extended bdinfo
    1m 03.25s: opened blu-ray
    DVDFab 8.1.1.2 (2011/08/11 10:20:58)
    0m 01.76s: option dvd2dvd 0 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2mobile 1 filemover 1
    0m 01.76s: Qt Translator file load success
    0m 07.98s: detected blu-ray
    0m 07.98s: drive E
    0m 07.98s: blu-ray type 1
    0m 07.98s: volume label GLADIATOR_D1
    0m 08.26s: aacs 1 bd+ 0
    0m 10.68s: got discinfo
    0m 10.95s: got bdmv
    0m 10.95s: Vendor: HL-DT-ST
    0m 10.95s: Product: BDDVDRW CH10LS20
    0m 10.95s: Revision: 1.00
    0m 10.95s: Vendor specific: 4
    0m 10.95s: AACS version: 1
    0m 10.95s: Number of concurrent AGIDs: 1
    0m 10.95s: Supports bus encryption: NO
    0m 10.95s: Supports binding nonce generation: YES
    0m 10.95s: Supports Hybrid discs: YES
    0m 10.95s: got agid 0
    0m 10.96s: sent host cert chal
    0m 10.98s: got drive cert chal
    0m 10.98s: BEC 0
    0m 10.98s: DRIVE_VENDOR 0x0116
    0m 11.01s: got drive key
    0m 11.79s: got host key signature
    0m 11.79s: verified drive signature
    0m 11.79s: verified host signature
    0m 11.84s: sent host signature and key point
    0m 11.84s: got bus key
    0m 11.85s: got agid 0
    0m 11.87s: sent host cert chal
    0m 11.87s: got drive cert chal
    0m 11.87s: BEC 0
    0m 11.87s: DRIVE_VENDOR 0x0116
    0m 11.90s: got drive key
    0m 11.90s: got host key signature
    0m 11.90s: verified drive signature
    0m 11.91s: verified host signature
    0m 11.95s: sent host signature and key point
    0m 11.95s: got bus key
    0m 11.95s: got volume id
    0m 11.95s: got volume id mac
    0m 11.95s: volume id is correct
    0m 11.95s: got vid
    0m 12.04s: blu-ray 262244E8C4747B200635F97424777927AC72D43F
    0m 12.54s: cert BEE=0x00 same
    0m 12.54s: got vuk
    0m 12.54s: got unit key 7
    0m 57.37s: got extended bdinfo
    0m 57.37s: opened blu-ray
    2m 30.63s:
    2m 30.63s: info: create config(5)
    2m 30.63s: info: convert profile(ps3.default)
    2m 30.65s: info: bluray playlist(300),angle(0),chapter(1->1),3D(0)
    2m 30.65s: info: streams((4113.2)(4352.2)(4608.8))
    2m 30.66s: info: not set correct fourcc for video(28)
    2m 30.66s: info: set output video frame_rate(24000/1001)
    2m 30.69s: info: subpicture preset(1), mode(0)
    2m 30.69s: info: create stream(1-0), unit_size(327680), unit_count(100), memory_size(31.25)MB
    2m 30.71s: info: enable multi-thread software decoder
    2m 30.71s: info: create stream(1-0), unit_size(3110400), unit_count(45), memory_size(133.484)MB
    2m 31.78s: info: create stream(1-0), unit_size(2350080), unit_count(45), memory_size(100.855)MB
    2m 31.80s: info: h264_encode: encode param profile(2) level(41) bitrate(5635)
    2m 33.83s: info: create stream(1-0), unit_size(58756), unit_count(100), memory_size(10)MB
    2m 33.83s: info: create stream(2-1), unit_size(10485760), unit_count(1), memory_size(10)MB
    2m 33.83s: info: create stream(2-1), unit_size(192000), unit_count(100), memory_size(18.3125)MB
    2m 33.83s: info: subpicture(4608) mode(0)
    2m 33.84s: info: connect to sub render filter
    2m 33.84s: info: create stream(5-2), unit_size(4194304), unit_count(1), memory_size(4)MB
    2m 35.87s: info: processing source(00201.m2ts)
    22m 46.91s:
    ------ finish mobile work ------
    DVDFab 8.1.1.2 (2011/08/11 10:47:13)
    0m 01.71s: option dvd2dvd 0 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2mobile 1 filemover 1
    0m 01.71s: Qt Translator file load success
    0m 10.82s: detected blu-ray
    0m 10.82s: drive E
    0m 10.82s: blu-ray type 1
    0m 10.82s: volume label GLADIATOR_D1
    0m 11.10s: aacs 1 bd+ 0
    0m 15.39s: got discinfo
    0m 15.66s: got bdmv
    0m 15.67s: Vendor: HL-DT-ST
    0m 15.67s: Product: BDDVDRW CH10LS20
    0m 15.67s: Revision: 1.00
    0m 15.67s: Vendor specific: 4
    0m 15.67s: AACS version: 1
    0m 15.67s: Number of concurrent AGIDs: 1
    0m 15.67s: Supports bus encryption: NO
    0m 15.67s: Supports binding nonce generation: YES
    0m 15.67s: Supports Hybrid discs: YES
    0m 15.67s: got agid 0
    0m 15.69s: sent host cert chal
    0m 15.69s: got drive cert chal
    0m 15.69s: BEC 0
    0m 15.69s: DRIVE_VENDOR 0x0116
    0m 15.72s: got drive key
    0m 16.52s: got host key signature
    0m 16.52s: verified drive signature
    0m 16.52s: verified host signature
    0m 16.55s: sent host signature and key point
    0m 16.55s: got bus key
    0m 16.56s: got agid 0
    0m 16.58s: sent host cert chal
    0m 16.59s: got drive cert chal
    0m 16.59s: BEC 0
    0m 16.59s: DRIVE_VENDOR 0x0116
    0m 16.62s: got drive key
    0m 16.62s: got host key signature
    0m 16.62s: verified drive signature
    0m 16.62s: verified host signature
    0m 16.66s: sent host signature and key point
    0m 16.66s: got bus key
    0m 16.66s: got volume id
    0m 16.66s: got volume id mac
    0m 16.66s: volume id is correct
    0m 16.67s: got vid
    0m 16.77s: blu-ray 262244E8C4747B200635F97424777927AC72D43F
    0m 17.26s: cert BEE=0x00 same
    0m 17.26s: got vuk
    0m 17.26s: got unit key 7
    1m 01.91s: got extended bdinfo
    1m 01.91s: opened blu-ray
    1m 56.47s:
    1m 56.47s: info: create config(5)
    1m 56.47s: info: convert profile(ps3.default)
    1m 56.47s: info: bluray playlist(300),angle(0),chapter(1->1),3D(0)
    1m 56.47s: info: streams((4113.2)(4352.2)(4608.8))
    1m 56.50s: info: not set correct fourcc for video(28)
    1m 56.50s: info: set output video frame_rate(24000/1001)
    1m 56.50s: info: subpicture preset(1), mode(0)
    1m 56.51s: info: create stream(1-0), unit_size(327680), unit_count(100), memory_size(31.25)MB
    1m 56.51s: try to use gpu acceleration(1) for video decoding
    1m 56.51s: CUDA GPU acceleration for video decoding enabled
    1m 56.53s: info: create stream(1-0), unit_size(3110400), unit_count(45), memory_size(133.484)MB
    1m 56.53s: info: create stream(1-0), unit_size(2350080), unit_count(45), memory_size(100.855)MB
    1m 56.54s: CUDA GPU acceleration for video encoding enabled
    1m 56.54s: info: h264_encode: encode param profile(2) level(41) bitrate(5635)
    1m 56.72s: info: create stream(1-0), unit_size(58756), unit_count(100), memory_size(10)MB
    1m 56.72s: info: create stream(2-1), unit_size(10485760), unit_count(1), memory_size(10)MB
    1m 56.73s: info: create stream(2-1), unit_size(192000), unit_count(100), memory_size(18.3125)MB
    1m 56.73s: info: subpicture(4608) mode(0)
    1m 56.73s: info: connect to sub render filter
    1m 56.73s: info: create stream(5-2), unit_size(4194304), unit_count(1), memory_size(4)MB
    1m 56.73s: info: processing source(00201.m2ts)
    13m 24.29s:
    DVDFab 8.1.1.2 (2011/08/11 11:02:58)
    0m 01.73s: option dvd2dvd 0 dvd2mobile 1 bluray2bluray 0 bd2mobile 1 bd23d 1 bd2dvd 1 file2mobile 1 filemover 1
    0m 01.74s: Qt Translator file load success
    0m 20.54s: detected blu-ray
    0m 20.54s: drive E
    0m 20.54s: blu-ray type 1
    0m 20.54s: volume label GLADIATOR_D1
    0m 20.81s: aacs 1 bd+ 0
    0m 23.77s: got discinfo
    0m 24.05s: got bdmv
    0m 24.07s: Vendor: HL-DT-ST
    0m 24.07s: Product: BDDVDRW CH10LS20
    0m 24.07s: Revision: 1.00
    0m 24.07s: Vendor specific: 4
    0m 24.07s: AACS version: 1
    0m 24.07s: Number of concurrent AGIDs: 1
    0m 24.07s: Supports bus encryption: NO
    0m 24.07s: Supports binding nonce generation: YES
    0m 24.07s: Supports Hybrid discs: YES
    0m 24.07s: got agid 0
    0m 24.08s: sent host cert chal
    0m 24.08s: got drive cert chal
    0m 24.08s: BEC 0
    0m 24.08s: DRIVE_VENDOR 0x0116
    0m 24.11s: got drive key
    0m 24.91s: got host key signature
    0m 24.91s: verified drive signature
    0m 24.91s: verified host signature
    0m 24.94s: sent host signature and key point
    0m 24.94s: got bus key
    0m 24.96s: got agid 0
    0m 24.97s: sent host cert chal
    0m 24.97s: got drive cert chal
    0m 24.99s: BEC 0
    0m 24.99s: DRIVE_VENDOR 0x0116
    0m 25.02s: got drive key
    0m 25.02s: got host key signature
    0m 25.02s: verified drive signature
    0m 25.02s: verified host signature
    0m 25.05s: sent host signature and key point
    0m 25.05s: got bus key
    0m 25.05s: got volume id
    0m 25.05s: got volume id mac
    0m 25.06s: volume id is correct
    0m 25.06s: got vid
    0m 25.16s: blu-ray 262244E8C4747B200635F97424777927AC72D43F
    0m 25.66s: cert BEE=0x00 same
    0m 25.66s: got vuk
    0m 25.66s: got unit key 7
    1m 10.48s: got extended bdinfo
    1m 10.48s: opened blu-ray
    2m 03.10s:
    2m 03.10s: info: create config(5)
    2m 03.10s: info: convert profile(ps3.default)
    2m 03.10s: info: bluray playlist(300),angle(0),chapter(1->1),3D(0)
    2m 03.10s: info: streams((4113.2)(4352.2)(4608.8))
    2m 03.11s: info: not set correct fourcc for video(28)
    2m 03.13s: info: set output video frame_rate(24000/1001)
    2m 03.13s: info: subpicture preset(1), mode(0)
    2m 03.13s: info: create stream(1-0), unit_size(327680), unit_count(100), memory_size(31.25)MB
    2m 03.13s: try to use gpu acceleration(1) for video decoding
    2m 03.13s: CUDA GPU acceleration for video decoding enabled
    2m 03.14s: info: create stream(1-0), unit_size(3110400), unit_count(45), memory_size(133.484)MB
    2m 03.14s: info: create stream(1-0), unit_size(2350080), unit_count(45), memory_size(100.855)MB
    2m 03.16s: CUDA GPU acceleration for video encoding enabled
    2m 03.16s: info: h264_encode: encode param profile(2) level(41) bitrate(5635)
    2m 03.28s: info: create stream(1-0), unit_size(58756), unit_count(100), memory_size(10)MB
    2m 03.28s: info: create stream(2-1), unit_size(10485760), unit_count(1), memory_size(10)MB
    2m 03.30s: info: create stream(2-1), unit_size(192000), unit_count(100), memory_size(18.3125)MB
    2m 03.30s: info: subpicture(4608) mode(0)
    2m 03.30s: info: connect to sub render filter
    2m 03.31s: info: create stream(5-2), unit_size(4194304), unit_count(1), memory_size(4)MB
    2m 03.31s: info: processing source(00201.m2ts)
    9m 35.28s: ------ cancel all mobile work -------
    Best settings are depending on your overall setup.
    An example is that I have a 295GTX and a AMD 1090T Hexcore CPU. The best settings for me is to enable CUDA Decode, but Software encode.
    I think a good point to make is that although the GPU is generally faster than the CPU, it does have a finite amount of resources. That being the case, I find a setup that splits the load across ALL system resources is what nets me the best performance results.
    For example, going CUDA for both encode/decode only puts my CPU at like, 20% utilization but according to GPU-Z, my GPU's video engine is pegged at 100%. While converting a Blu-Ray with these settings, I can get about 25fps.
    But when I set my video decode settings to CUDA and my encoder settings to software, I'm able to get 32-35fps with both my GPU and CPU at 100%.
    I think it's also important to note that, in general, CUDA isn't exactly great for encoding. CUDA forces all values to be single precision floating points when h.264 encoding generally only makes use of 8 and 16 bit integers. Meaning that although CUDA has more work units, it's generally less efficient at encoding when compared clock for clock/core for core to CPU's.
    That being said, what is IS good for (and has a video engine optimized for) is h.264 decoding. So my thinking (and at least what proof I can find) is let the video card do what it's good at (decoding) and let the CPU do what it's good at and I think you'll get optimal results
    Cheers!
      Good Stuff --- Thanks for the response - I appreciate your comments
        @enusbaum
        Great explanation! Couldn't say better. Thanks.
          "But when I set my video decode settings to CUDA and my encoder settings to software, I'm able to get 32-35fps with both my GPU and CPU at 100%"
          These settings work great ---- I'm now getting the same speeds as yourself and without any A/V sync problems -
          One more question - Now that I have these settings in the profile, is it easy to take a look at the GPU activity? --- CPU is not a problem as I can do that on the task manager but where do I look (curiosity only) to monitor the GPU?
          Thanks
            Thanks
            As he said, .
            AMD Phenom II X4 3.2Ghz | Radeon HD 4670 | Win7 Pro x64 | 8 GB | Synology DS211j 5TB | Wired GbE | 2x WDTV Live + |
              GPU-Z is meaningless to us less informed mortals - A sort of 'idiots guide' would be very welcome --- Nice easy steps to follow
              Thanks
                Thanks
                Not a fan of GPU-Z, eh?
                Graphic card manufacturers such as EVGA and MSI for eg., offer very decent utilities to monitor and tweak their respective cards.
                Since you have an EVGA GTX550, maybe EVGA Precision is more to your liking.
                I use it on occasion and have no complaints
                http://www.evga.com/precision/
                  nVIDIA System Monitor should be easy enough for you - simple desktop gadget. Try it from here http://www.nvidia.com/object/nvidia_...ools_6.05.html
                  sigpic
                    Thanks to all of you for the responses (and for your patience... I'm not really dumb, just unfamiliar but learning fast) -- As I'm fairly new to all of this, terms such as GPU-Z really don't mean much on their own and unfortunately, at my stage, I need a bit more of an explanation, such as those provided - I now have GPU-Z and there is a lot of info shown there - I'll also try the other utilities suggested and see how they compare - I'm sure I'll have other questions once I've tried them but I'll probably post under a new thread - Again, my thanks and appreciation for all your time
