Approximate Ripping Speeds?
    Other Approximate Ripping Speeds?
    Well, my new EVGA GTX 550 graphics card (and uprated PSU) did'nt really result in the dramatic improvement in BD ripping speeds (to PS3) that I had hoped for. I've tried using different combinations (CUDA is faster but results in an A-V synch problem) - Software only is still only about 25 fps conversion speed which is the same as my old card - Are there any indications as to what sort of conversion speeds (Average) I should be getting ? Anybody else out there getting faster speeds or about the same? I've tried all sorts of settings but nothing seems to improve matters that much - Even a straight rip to MKV is not any faster that the old card.... Suggestions would be very welcome - Thanks in advance
    DVDFab 8.1.1.2 (2011/08/12 09:16:02)
    0m 01.85s: option dvd2dvd 0 dvd2mobile 1 bluray2bluray 0 bd2mobile 1 bd23d 1 bd2dvd 1 file2mobile 1 filemover 1
    0m 01.85s: Qt Translator file load success
    DVDFab 8.1.1.2 (2011/08/12 09:16:29)
    0m 01.82s: option dvd2dvd 0 dvd2mobile 1 bluray2bluray 0 bd2mobile 1 bd23d 1 bd2dvd 1 file2mobile 1 filemover 1
    0m 01.82s: Qt Translator file load success
    0m 07.86s: detected blu-ray
    0m 07.86s: drive E
    0m 07.86s: blu-ray type 1
    0m 07.86s: volume label GLADIATOR_D1
    0m 08.08s: aacs 1 bd+ 0
    0m 10.54s: got discinfo
    0m 10.82s: got bdmv
    0m 10.82s: Vendor: HL-DT-ST
    0m 10.82s: Product: BDDVDRW CH10LS20
    0m 10.82s: Revision: 1.00
    0m 10.82s: Vendor specific: 4
    0m 10.82s: AACS version: 1
    0m 10.82s: Number of concurrent AGIDs: 1
    0m 10.82s: Supports bus encryption: NO
    0m 10.82s: Supports binding nonce generation: YES
    0m 10.82s: Supports Hybrid discs: YES
    0m 10.84s: got agid 0
    0m 10.85s: sent host cert chal
    0m 10.85s: got drive cert chal
    0m 10.85s: BEC 0
    0m 10.85s: DRIVE_VENDOR 0x0116
    0m 10.88s: got drive key
    0m 11.66s: got host key signature
    0m 11.66s: verified drive signature
    0m 11.68s: verified host signature
    0m 11.71s: sent host signature and key point
    0m 11.71s: got bus key
    0m 11.73s: got agid 0
    0m 11.74s: sent host cert chal
    0m 11.74s: got drive cert chal
    0m 11.74s: BEC 0
    0m 11.74s: DRIVE_VENDOR 0x0116
    0m 11.77s: got drive key
    0m 11.77s: got host key signature
    0m 11.77s: verified drive signature
    0m 11.77s: verified host signature
    0m 11.82s: sent host signature and key point
    0m 11.82s: got bus key
    0m 11.82s: got volume id
    0m 11.82s: got volume id mac
    0m 11.82s: volume id is correct
    0m 11.82s: got vid
    0m 11.91s: blu-ray 262244E8C4747B200635F97424777927AC72D43F
    0m 12.40s: cert BEE=0x00 same
    0m 12.40s: got vuk
    0m 12.40s: got unit key 7
    0m 56.73s: got extended bdinfo
    0m 56.73s: opened blu-ray
    3m 45.70s:
    3m 45.70s: info: create config(5)
    3m 45.70s: info: convert profile(mkv.remux)
    3m 45.70s: info: bluray playlist(12),angle(0),chapter(1->28),3D(0)
    3m 45.73s: info: streams((4113.1)(4352.1)(4608.16))
    3m 45.73s: info: subpicture preset(2), mode(2)
    3m 45.73s: info: create stream(1-0), unit_size(327680), unit_count(150), memory_size(46.875)MB
    3m 45.73s: info: create stream(2-1), unit_size(10485760), unit_count(500), memory_size(904)MB
    3m 45.73s: subpicture(4608) mode(2)
    3m 45.73s: info: create stream(5-2), unit_size(4194304), unit_count(1), memory_size(4)MB
    3m 45.74s: info: processing source(00102.m2ts)
    7m 34.86s: info: processing source(00198.m2ts)
    9m 55.12s: info: processing source(00104.m2ts)
    10m 01.85s: info: processing source(00105.m2ts)
    14m 00.01s: info: processing source(00106.m2ts)
    14m 04.46s: info: processing source(00201.m2ts)
    19m 05.36s: info: processing source(00236.m2ts)
    19m 08.99s: info: processing source(00204.m2ts)
    19m 19.66s: info: processing source(00226.m2ts)
    19m 24.04s: info: processing source(00208.m2ts)
    22m 03.88s: info: processing source(00227.m2ts)
    22m 09.56s: info: processing source(00206.m2ts)
    24m 16.89s: info: processing source(00228.m2ts)
    24m 20.32s: info: processing source(00210.m2ts)
    27m 22.42s: info: processing source(00229.m2ts)
    27m 27.21s: info: processing source(00213.m2ts)
    28m 19.03s: info: processing source(00230.m2ts)
    28m 24.09s: info: processing source(00215.m2ts)
    30m 55.03s: info: processing source(00231.m2ts)
    31m 06.14s: info: processing source(00217.m2ts)
    31m 56.51s: info: processing source(00232.m2ts)
    32m 37.34s: info: processing source(00219.m2ts)
    34m 41.83s: info: processing source(00233.m2ts)
    34m 47.07s: info: processing source(00221.m2ts)
    36m 12.34s: info: processing source(00234.m2ts)
    36m 47.58s: info: processing source(00223.m2ts)
    39m 19.95s: info: processing source(00235.m2ts)
    41m 28.96s:
    ------ finish mobile work ------
    50m 54.99s:
    50m 54.99s: info: create config(3)
    50m 54.99s: info: convert profile(PlayStation 3)
    50m 54.99s: info: file (.mkv),3D(0)
    50m 54.99s: info: streams((0.2)(1.2))
    50m 55.15s: info: not set correct fourcc for video(28)
    50m 55.15s: info: set output video frame_rate(24000/1001)
    50m 55.15s: info: create stream(1-0), unit_size(327680), unit_count(100), memory_size(31.25)MB
    50m 55.15s: info: enable multi-thread software decoder
    50m 56.23s: info: create stream(1-0), unit_size(3110400), unit_count(45), memory_size(133.484)MB
    50m 56.23s: info: h264_encode: encode param profile(2) level(41) bitrate(7458)
    50m 58.26s: info: create stream(1-0), unit_size(77768), unit_count(100), memory_size(10)MB
    50m 58.26s: info: create stream(2-1), unit_size(10485760), unit_count(1), memory_size(10)MB
    50m 58.26s: info: create stream(2-1), unit_size(192000), unit_count(100), memory_size(18.3125)MB
    96m 26.10s: ------ cancel all mobile work -------
    2011-08-12 10:53:00 ---- ******************** Log session stop 12-Aug 10:53:00.608 PID 3756********************
    2011-08-12 09:16:35 Info Current Drive selected : 1:0:0 - HL-DT-ST BDDVDRW CH10LS20 1.00 [E] (Ide)
    2011-08-12 09:16:35 Info Using Advanced SPTI interface
    2011-08-12 09:16:35 Info System default language : English (United States)
    2011-08-12 09:16:35 Info User default language : English (Canada)
    2011-08-12 09:16:35 Info DLL Version : 4.0.20.488
    2011-08-12 09:16:35 Info DLL : C:\Program Files (x86)\DVDFab 8 Qt\vso_hwe.dll
    2011-08-12 09:16:35 Info Version : 8, 1, 1, 2
    2011-08-12 09:16:35 Info ExeName : C:\Program Files (x86)\DVDFab 8 Qt\DVDFab.exe
    2011-08-12 09:16:35 Info OS : Microsoft Windows 7 Professional (Build 7601: Service Pack 1)
    2011-08-12 09:16:35 ---- ******************** Log session start 12-Aug 09:16:35.092 PID 3756***********
    Not sure if this will help, but as data points for comparison...
    My home built rig is just about 2 years old now...the guts are:
    Intel Core i7-920 Bloomfield 2.66GHz LGA 1366 130W Quad-Core Processor
    EVGA 896-P3-1257-AR GeForce GTX 260 Core 216 Superclocked Edition 896MB 448-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI
    Win7 Pro 64-bit
    My results were similar to yours.
    Used True Grit as a test and while I don't have a PS3, I used the default settings in Fab for this profile and used VLC for playback.
    With CUDA, fps averaged about 45-50.
    Without CUDA (software only...I don't have Core AVC), my fps was 35-40.
    I did note av sync problems with both the CUDA enabled conversion and the software only conversion. Roughly evident about 1/3 of the way through to the end.
    I only used v.8.1.1.2 for testing.
    I never experience av issues or any other issues with standard dvd convsersions, but like many, I find BD conversions is a huge can of worms.
    Simply, BD conversions are very labor intensive.
    (My fps for standard dvd conversions average about 300-500 fps depending on the profile. The video quality is great and the resultant file size is approx 25% of original)
    BD MKV remux, etc., works, but can have problems with HD audio and subtitles, particularly with respect to my media player.
    While these problems can be rectified, I gain nothing and the cost/benefit ratio is awful...JMO
    Ultimately, I don't convert BD files, I just stick 'em on 2 TB hdds in a couple media servers (total of 16 TB)
    I use BD25 for main movie or sometimes BD9 which has outstanding video quality when viewed on a 42" HDTV via a media player
      Conversion Speeds
      That's great - Thanks very much for your response - It looks like we have pretty much the same results and speeds - Thanks again
