Is anyone having problems backing up the movie Priest?
The question is.......are you having problems with it?
If so then post your logs.
I have seen problems with Priest posted on other forums and more than one update on other forums to handle it so I assume Fab will need an update also.
Can you send the info to Fab so they can take a look at it?
Clean the movie disc even it looks clean before you copy.
Then open DVDFab, click the tick green icon button at the right top corner of the DVDFab screen, open "Common Settings" window, click on "Read", select "ignore all the reading errors automatically" to copy again and see if it will help.
