registration key question
    License/Key registration key question
    i purchased a master key for $260, and i have 2 pcs and want to double my use. can i use the master key for the second and it work with no issue?
    Yes the key will work on the second PC but...... Do not use both of them at the same time if they are both connected to the internet as this could cause the key to be blacklisted.
