this is a question for DVD Fab 8.1.1.2
In the preferences->General->A/V Codec, when I try to select "AMD APP" for the video decoder for H.264, VC1, or MPEG2, i get the following alert dialogs, respectively:
in the "Codec Information" window on that page this is what is displayed:
I have an AMD Radeon HD6850 video card, which is supposed to support AMD APP. Is there something I am missing to enable AMD APP?
Here is my driver information for the 6850 (the AMD Catalyst Control Center app says it's up to date):
and my hardware info for the 6850
- AMD APP H.264 decoder cannot be supported by your graphics card
- AMD APP VC1 decoder cannot be supported by your graphics card
- AMD APP MPEG2 decoder cannot be supported by your graphics card
Code:
Graphics Chipset : AMD Radeon HD 6800 Series Supported Video Codecs : DXVA_MODE_H264 DXVA_MODE_VC1 DXVA_MODE_MPEG2 CoreAVC : cannot be detected.
Code:
Driver Packaging Version 8.881-110728a-122939C-ATI Provider ATI Technologies Inc. 2D Driver Version 8.01.01.1178 2D Driver File Path /REGISTRY/MACHINE/SYSTEM/ControlSet001/Control/CLASS/{4D36E968-E325-11CE-BFC1-08002BE10318}/0002 Direct3D Version 7.14.10.0855 OpenGL Version 6.14.10.11005 Catalyst Control Center Version 2011.0728.1756.30366 AMD Audio Driver Version 7.12.0.7702
Code:
Primary Adapter Graphics Card Manufacturer Powered by AMD Graphics Chipset AMD Radeon HD 6800 Series Device ID 6739 Vendor 1002 Subsystem ID 21F8 Subsystem Vendor ID 1458 Graphics Bus Capability PCI Express 2.0 Maximum Bus Setting PCI Express 2.0 x16 BIOS Version 013.007.000.003 BIOS Part Number 113-AC91000-100 BIOS Date 2010/11/15 Memory Size 1024 MB Memory Type GDDR5 Core Clock in MHz 820 MHz Memory Clock in MHz 1050 MHz Total Memory Bandwidth in GByte/s 134.4 GByte/s
