QuickSync and CUDA Bug Report..
    CPU/GPU QuickSync and CUDA Bug Report..
    All the versions after 8.1.1.2 I have tried have this problem...
    If you shrink a BD50 down to BD25 with QuickSync or CUDA AND select "Remove HD Audio" there is a problem.
    QuickSync takes hours to work and CUDA just quits and finishes the job after about 10 seconds.
    Hopefully this will get fixed.
    @martythebrit
    please specify, IQS and CUDA for encoder or decoder, or both produces this issue
    sigpic
      Both...
        @martythebrit
        Please try:
        (a) to set decoder for IQS or CUDA and encoder for software;
        (b) both encoder and decoder for software;
        and report result here.
        sigpic
          Both cause the same problem.
          If I disable GPU codecs everything is fine.
            @martythebrit
            Unfortunately I can't reproduce this problem. If I have set for CUDA decoder and software encoder, with "Remove HD Audio" checked everything works just fine..
            sigpic
              Do you have QuickSync too?
              This would be a different motherboard/system than yours.
              Also, I'm using an Nvidia GTS450 video card and Lucidlogix VIRTU.
              My MoBo is an Intel DH67CL.
                No, I don't have IQS. I like my CUDA
                sigpic
                  I like my CUDA too!
                  QuickSync just kinda happened with my mobo upgrade...
                  It runs a little quicker than CUDA, nothing to write home about though.
