Dvd5 ???
    Dvd5 ???
    Every time I start a new copy I have to set the quality to DVD5. Can I do something to make it stay on DVD5 instead of always going back to DVD9? I have memorize user interface options checked. I am also doing more than one movie at a time on my computer, each has it's own HD and DVD burner.
    Thanks in advance for any information,
    User6895
    @User6895
    You can set output to DVD5 in Common Settings (little green checkmark in top right corner of DVDFab main window).
    sigpic
      Wish I had a nickel for every time I have posted this attachment.
        I wish too You would of send your private jet to pick me up and fly to visit you
        sigpic
          One more question...
          Thanks for the info, that problem is fixed. With more than one instance of DVDFab running on my computer will I have any problems with all of them set to check for updates automatically or should I only let one of them check for updates???
          Thanks Again, User6895
            @User6895
            If you running different versions, only latest should be set for updates check.
            If they all same version, they all identical anyway - only one is enough.
            sigpic
