Drivers
    CPU/GPU Drivers
    The last few times I used DVDFAB, It pops up and says that I need to update my drivers on my video card. This is a new built rig, my first! I have an EVGA Gforce GTX 460 SuperClocked, core763MHz! When I got the card it had the drivers already installed v206.82 I think! I've always done dvdcopy on an old pc, XP SP3! Now I've have overclocked my system for gaming and after I did that now I get the message from FAB to update my video card drivers! Could the OCing cause this message from fab, or do I need to update my video card? I've been useing Blu-ray copy, (trail version) and has been working great! I'm new to all of this Blu-ray stuff!, but how do I go about updateing my video card?(drivers) Might sound dumb, but got to start somewhere!
    NVIDIA's web site would be a starting point.
      90312, Thank you! Will return if need more Info!
        Latest drivers are 280.26.
        Beta's are 285.27, used at your own risk.
          drivers
          MARTYTHEBRIT, I was just about to asked that Question about the beta version! I have the latest drivers, but seen the beta-driver, but didn't use it! When I clicked on the green checkmark, a/v codec, it showed under codec Info the first time I looked, it showed CUDA capability revision number-2.0, then when I came back from EVGA's website and checked FAB again, the revision number was 2.1, and I didn't do anything or D/L anything! Can you explain this, or does Fab do it for you! I swear it changed by its self!, and I'm not getting the message anymore, to update card! Thanks for posting about the beta-version!
            Been using the beta's for about a week now without issue.
            Your mileage may vary...
              CPU/GPU drivers
              Martythebrit, after reading your post, I decided to Install the beta-driver, I've done both dvd and blu-rays and haven't had any problems so far! Thanks!
                Glad I could help!
