Problem with zookeeper
    Hello,
    I am able to backup Zookeeper, however, it does not play right. Basically, what I am hearing is the main problem. The audio portion seems to be dubbed out, and replaced with some kind of music that plays constantly. I did see a warning about a protection called cinavia located on the disk that could cause it not to play properly on certain players. I am in Region 1, using vs 8.1.2.8 beta in Free HD Decyrpter. What log that there was is attached.
    You mentioned the Fab team was on vacation until after the 8th, is that November 8th. I didn't pay attention any date when I saw it.
    DVDFab 8.1.2.8 (2011/10/16 07:54:45)
    0m 06.50s: Qt Translator file load success
    0m 07.28s: option dvd2dvd 0 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2mobile 1 filemover 1
    0m 28.06s: detected dvd
    0m 28.10s: drive E
    0m 28.10s: dvd type 1
    0m 28.12s: volume label ZOOKEEPER
    0m 28.71s: got copyright 1 f6
    0m 29.81s: got udf/iso
    0m 32.81s: got discinfo
    0m 32.96s: blu-ray 9B18883EA10538F4BE45CCF8CB975F09083417D7
    0m 32.96s: cert BEE=0x00
    0m 37.17s: detected cinavia
    0m 37.18s: pathplayer enabled
    0m 55.32s: got dvdinfo
    0m 55.34s: opened dvd
    a protection
    Hi jetman4615
    According to your logs it seems that the trial has expired and if using the free HD Decrypter you would have to wait 60-90 days before new movies will be supported.
    You must either buy the program or wait until it is supported.
    CBR929
      Hi jetman4615
      CBR929
      Apparently, sometime in the past, I must have selected the trial of DVD Copy. It seems that has caused me grief, since I never really used DVD Copy. Is there anyway I can revert back to the original usage of HD Decerypter by eliminating the expired notation, possibly by removing DVD FAB completely, and reinstalling. Thanks for your assistance.
