not enough space on c drive?? need help
    Hi everyone.
    I have a bit of a problem, i only have 17.8gb space on my C drive, i've deleted everything i can from there to get this.
    anyway this is the problem, i have a solid state hard drive (60gb) as my C drive which i planned to use just to run the operating system, i also have a 500gb hard drive and a 1T HDD in my pc as well. the question i have is if ive installed dvdfab to the D drive (which i have) shouldnt that be enough space on there without it asking about the C drice?
    i need a way around this so it doesnt look to the C drive, if anyone has any answers you will make me very happy.
    Thanks in advance
    You simply need to output your temporary directory and output directory to your 500 GB or 1 TB drive(s) (something other than your c: drive).
    The default file path is your c: drive
    Enter Fab's Common Settings > General
    and alter the file paths of these directories.
    Also, it is likely that
    Delete temporary files when done
    is unticked.
    This will chew up your hdd spce in a hurry if unticked inadvertantly.
    The program installation itself takes up mininal space (almost insignificant).
      In common settings select general and change the output directory and the directory used for the temporary files used during ripping to a drive other than C: and give it a try. See attached:
      I'm too old and slow mainman!
        Hahaha...
        Nah, no one's older and slower than me.
        You added a nice, fancy screenshot.
        Whenever I do...I always come in last...
          Originally posted by maineman View Post
          Hahaha...
          I guess I do too
            A big thank you
            is unticked.
            wow thank you both so much, that was so simple, guess thats how it usually goes.
            Again thank you, i was getting very annoyed with it.
