Problem never came across before.
    I know there is this big thing with Cinavia thing. I have Bad Teacher. I read updated my Fab everything right. Okay well. I got it burned watched my own disk last night NO PROBLEMS. But now when I am trying to make another copy it is reading disk error from my own personal disk??? I have NEVER had my own personal disk that is BRAND new, only watched once do this before. The only time I ever get this error is with like my older movies that are so scratched you can't hardly watch them anymore. It is the same error I always get with worn out disk, but only this disk is NOT worn out by no means?????
    "Error while reading!Please choose what to do?
    Retry Abort Ignore Ignore All
    What the heck? It is not the actual Bad Teacher disk, but my own disk I made from the original. I have never had this happened with a so called "burnt" disk before, like I said unless burnt or not burnt the disk is worn out. This one is in PERFECT cond.
    Update: It is not just Bad Teacher. It is doing this with every single already burnt disk I have period. I tested it out to see if it was just Bad Teacher. It is doing it with X-Men, The Messanger, The Fourth Kind, that is just a few to name. All are my personal burnt ones, which I did on DVD Fab. And I have been using DVD Fab over almost 7 months, never have I had this happen.
    Someone PLEASE help me out. What the heck is going on here?
    Try disabling PathPlayer.
      What the heck is path player???? Never heard of it before
        I read about it,but i have no clue where it is....That is what has me so most, I can't find settings on my DVD Fab at all???? Where the heck are the settings?
          click the green circle at the top with the white check mark in it, you'll see PathPlayer in the list.
            Thanks I just found it about the time you wrote. Thanks so much. I did it and the read opt as well. See if that helps. Thanks so much. I sure hope it works, it just weird all a sudden it starts doing it on everything i put in there. LOL< brand new, old, or worn out didn't matter. Thanks so much. See if it helps.
              Be sure to set it back to always enabled when finished.
                Thanks sure will. I got a bit busy forgot about it all for a moment. working on it now, now just have to check new copy make sure it works right. I took the DVDs this time, I just gotta wait till the WHOLE process is done and test it out on my dvd player
                  wait your good news!
