When i burn a movie to either a disc or to my hard drive, the audio and video are synced correctly, but the overall playback is no smooth, kind of stuttering and choppy, its hard to describe, but its just not smooth. Any ideas on how to fix this?
video playback issues
Originally posted by Dan2011 View PostWhen i burn a movie to either a disc or to my hard drive, the audio and video are synced correctly, but the overall playback is no smooth, kind of stuttering and choppy, its hard to describe, but its just not smooth. Any ideas on how to fix this?
We need the detailed information as follows for troubleshooting.
1) Which product you were using, DVDFab DVD Copy or DVDFab Blu-ray Copy
2) Which video player you were using
3) Please post your log files.
The default location is:
Anny
PS3 playback
This problem is being reported more and more lately and it is one that I have mentioned before. As I have reported, the problem does not exist with any BD rips done with Version 8085 --. Even now, new BD releases (Green Lantern, etc) when ripped with 8132 exhibit the 'stutter' problem. If the same movie is ripped with 8085, it streams perfectly. the 'stuttering' sems to have begun when the qt series were introduced and as I understand the situation, the DVD Fab team were looking into applying a fix.
heres the log for a movie i burned, the problem exists on all media players--pc laptop, ipad and ps3
1m 11.13s: info: create config(0)
1m 11.13s: info: convert profile(PlayStation 3)
1m 11.13s: info: dvd playlist(1),angle(0),chapter(1->25),3D(0)
1m 11.13s: info: streams((480.2)(128.2))
1m 11.43s: info: not set correct fourcc for video(28)
1m 11.44s: info: set output video frame_rate(24000/1001)
1m 13.46s: info: h264_encode: encode param profile(2) level(41) bitrate(1399)
2m 21.64s: error: filter name(native_mux), type(128), id(11), get fatal exception
2m 36.79s: ------ mobile work failed(504.00 0 error: filter name(native_mux), type(128), id(11), get fatal exception
5m 32.75s: detected dvd
5m 32.81s: drive D
5m 32.92s: dvd type 1
5m 32.92s: volume label NT20NNW1
5m 33.95s: got copyright 1 fe
5m 34.43s: got udf/iso
5m 36.86s: got discinfo
5m 36.90s: pathplayer enabled
DVDFab 8.1.3.1 (2011/11/07 20:17:42)
5m 54.41s: got dvdinfo
5m 55.46s: opened dvd
0m 11.77s: Qt Translator file load success
0m 11.79s: import key file D:\ 1
0m 15.02s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 0 bd2dvd 1 file2mobile 1 filemover 1
0m 24.67s: detected dvd
0m 24.96s: drive D
0m 24.96s: dvd type 1
0m 25.11s: volume label NT20NNW1
0m 32.12s: got copyright 1 fe
0m 40.98s: got udf/iso
0m 52.58s: got discinfo
0m 52.58s: pathplayer enabled
1m 18.84s: pathplayer drive error 1
1m 18.85s: pathplayer drive error 1
1m 19.15s: failed to open disc 1
7m 16.41s:
7m 16.41s: info: create config(0)
7m 16.41s: info: convert profile(PlayStation 3)
7m 16.41s: info: dvd playlist(4),angle(0),chapter(1->19),3D(0)
7m 16.41s: info: streams((480.2)(128.2))
7m 16.89s: info: not set correct fourcc for video(28)
7m 16.91s: info: set output video frame_rate(24000/1001)
7m 19.50s: info: h264_encode: encode param profile(2) level(41) bitrate(782)
21m 53.96s:
------ finish mobile work ------
