Here's a whopper of a question. They bought a new computer. I used to have Windows XP and now it's Windows 7. What I did next is, grab the old hard drive and linked it to the new computer. Now I can switch from either or. Now what I want to do is find out my registration so that I can just download the DVD Fab 8 and put in the registration key that way I don't have to pay again for another key[CODE. Where can I find this and how can I put this registration key code in the new one.
Registration Key
Hi prican1493
I am a llitle confused, which by the way isn't to hard for me.
Did you transfer every thing over to the new computer Hdd?
You will not have to buy a new Key unless your new subscription is due.
Go here http://www.dvdfab.com/member.htm
Log in with your E-mail that you used when you purchased Fab and create a password and you can get your Key(s) for the options that you have purchased.
Hope this helps
CBR929Even if it's a little thing, do something for those who have need of help, something for which you get no pay but the privilege of doing it.
