Option to "Move" DVDFab Folder
    It would be great if DVDFab would give the user an option to select where the DVDFab folder, which is now located under My Documents, should reside. Even better would be if the user can use another folder all together (diff. name and loacation). Has this been talked about before?
    Nope cause you can already do it in "Settings"
      Yeah, but that folder still gets created.
        So?
          I don't want folders I don't use to exists.
            Well, you are just gonna have to get used to it.
            Similar requests have been made over the years to no avail.
