; ImgBurn Version 2.5.6.0 - Log
; Tuesday, 13 December 2011, 12:33:27
I 12:17:21 ImgBurn Version 2.5.6.0 started!
I 12:17:21 Microsoft Windows 7 Home Premium x64 Edition (6.1, Build 7601 : Service Pack 1)
I 12:17:21 Total Physical Memory: 8,371,320 KB - Available: 6,910,860 KB
I 12:17:21 Initialising SPTI...
I 12:17:21 Searching for SCSI / ATAPI devices...
I 12:17:21 -> Drive 1 - Info: Optiarc DVD RW AD-7260S 1.03 (E
(ATA)
I 12:17:21 -> Drive 2 - Info: PIONEER BD-RW BDR-206D 1.06 (D
(ATA)
I 12:17:21 Found 1 DVD±RW/RAM and 1 BD-RE!
I 12:18:24 Operation Started!
I 12:18:24 Building Image Tree...
W 12:18:25 Removed Filtered File: \KUNG_FU_PANDA_2.miniso
I 12:18:32 Corrected file system selection for Blu-ray Video disc.
I 12:18:32 Corrected UDF revision selection for Blu-ray Video disc.
I 12:18:32 Calculating Totals...
I 12:18:32 Preparing Image...
I 12:18:32 Contents: 9 Files, 15 Folders
I 12:18:32 Content Type: BD Video
I 12:18:32 Data Type: MODE1/2048
I 12:18:32 File System(s): UDF (2.50)
I 12:18:32 Volume Label: KUNG_FU_PANDA_2-blue-ray
I 12:18:32 Size: 19,510,373,700 bytes
I 12:18:32 Sectors: 9,526,556
I 12:18:32 Image Size: 19,511,377,920 bytes
I 12:18:32 Image Sectors: 9,527,040
I 12:18:32 Operation Successfully Completed! - Duration: 00:00:07
I 12:18:32 Operation Started!
I 12:18:32 Source File: -==/\/[BUILD IMAGE]\/\==-
I 12:18:32 Source File Sectors: 9,527,040 (MODE1/2048)
I 12:18:32 Source File Size: 19,511,377,920 bytes
I 12:18:32 Source File Volume Identifier: KUNG_FU_PANDA_2-blue-ray
I 12:18:32 Source File Volume Set Identifier: 3F8D624C00915E9C
I 12:18:32 Source File Application Identifier: ImgBurn v2.5.6.0
I 12:18:32 Source File Implementation Identifier: ImgBurn
I 12:18:32 Source File File System(s): UDF (2.50)
I 12:18:32 Destination Device: [0:1:0] PIONEER BD-RW BDR-206D 1.06 (D
(ATA)
I 12:18:32 Destination Media Type: BD-R (Disc ID: VERBAT-IMe-000)
I 12:18:32 Destination Media Supported Write Speeds: 2x, 4x, 6x, 8x, 10x, 12x
I 12:18:32 Destination Media Sectors: 12,219,392
I 12:18:32 Write Mode: BD
I 12:18:32 Write Type: DAO
I 12:18:32 Write Speed: 6x
I 12:18:32 BD-R Verify Not Required: Yes
I 12:18:32 Link Size: Auto
I 12:18:32 Lock Volume: Yes
I 12:18:32 Test Mode: No
I 12:18:32 OPC: No
I 12:18:32 BURN-Proof: Enabled
I 12:18:32 Write Speed Successfully Set! - Effective: 26,970 KB/s (6x)
I 12:18:32 Advanced Settings - Optimal Writing Speed: No
I 12:18:32 Filling Buffer... (385 MB)
I 12:18:39 Writing LeadIn...
I 12:18:52 Writing Session 1 of 1... (1 Track, LBA: 0 - 9527039)
I 12:18:52 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 9527039)
I 12:31:13 Synchronising Cache...
I 12:31:14 Closing Track...
I 12:31:15 Finalising Disc...
I 12:31:28 Exporting Graph Data...
I 12:31:28 Graph Data File: C:\Users\Arlin\AppData\Roaming\ImgBurn\Graph Data Files\PIONEER_BD-RW_BDR-206D_1.06_TUESDAY-DECEMBER-13-2011_12-18_PM_VERBAT-IMe-000_6x.ibg
I 12:31:28 Export Successfully Completed!
I 12:31:28 Operation Successfully Completed! - Duration: 00:12:51
I 12:31:28 Average Write Rate: 25,714 KB/s (5.7x) - Maximum Write Rate: 27,061 KB/s (6.0x)
I 12:33:27 Close Request Acknowledged
I 12:33:27 Closing Down...
I 12:33:27 Shutting down SPTI...
I 12:33:27 ImgBurn closed!
;Could someone explain the miniso file to me? I got a yellow warning sign while I was burning this Blu-ray with Imgburn! Do I need to reset anything? Thanks for the help!
I 12:18:32 OPC: No
