I'm having problems with changing regions on my PC, and would appreciate any help or suggestions people can offer.
I'm using PowerDVD 11 Ultra on Windows 7 SP1, and DVDFab 8.0.4.2. If I play a Blu-ray disc from one region, and then want to play one from a different region, then PowerDVD stops loading the disc. I have to completely reboot my PC, and then PowerDVD will play it.
The makers of PowerDVD, of course, are blaming DVDFab. And it may be true: if I use the option inside PowerDVD to change the region the software is set for, then I have no problems: at most I have to restart PowerDVD, but not the whole computer, and then the disc plays straight away. But PowerDVD only lets you change region 5 times in total, and then the region is permanently locked.
So, is this the way the DVDFab software works? Does a change between regions always require a reboot?
