Blu Ray Temp main movie copy
    Hi, I have copied my movie straight to disc but I keep a copy of all my films on my hard drive as well at the same time. My copied disc has been damaged and i want to make another copy from my hard drive. Could someone please advise how I can use the files in my temp folder to burn another disc. Cheers.
    Recommend that you use Write Data mode.
    Quick and easy.
    This will burn the hdd file directly to your blank media....ie., no re-encoding, etc.
    Simply select the hdd file as Source.
    Keep in mind that the hdd file must be able to fit on your blank disc as no compression is possible in this mode.
    Otherwise, you'll have to re-rip.
