Where can I get hold of 8.0.7.3
    Does anyone know where I can get hold of release 8.0.7.3? I ripped a DVD with it last year, but now want to increase the resolution. The file has a timestamp of early Feb 2011, so I know the DVDFab version will either be 8.0.7.3 or a beta there after.
    When I try with the latest version to create a mp4 file (or even 8.0.8.5) - the DVD fails to rip and stops around 67%. If I rip to HD first, that works OK, but then there is an issue with video / audio sync.
    Now it is not just 1 DVD that is an issue but around 10% of my library (40ish in total). Other DVDs are fine - hence I want to try an older version of the software.
    Any help would be much appreciated.
    Fab does not officially support older versions.
    However, this site has been linked here on the forum many times and has been used by many members
    and I've never heard of a problem.
    HTH
