OK I wasn't sure if this should be a feature request or if it's a small bug.
If you enter an illegal character the filename, nothing is reported back to the end user about it.
If you actually run the conversion, the file is created, with it's name up to the illegal character. The process completes succesfully, but the file generated is 0 bites in size.
I think there should be a little checking for such characters in the filename and an error/alert be posted back to the end user informing them of the problem.
Please note: I'm the king of typo's so I've had this happen a couple times now
