Ripping a DVD/Bluray to AVI or MKV gives video glitch
    When ripping a DVD to AVI/H264 the video gets some faulty video static.
    Tried ripping directly from the disc and copied dvd with dvddecrypter, i still get a video with some kind of videoframe with a thick grey line (like a dvd has scratches and skipping a frame).
    Tried another program to rip a dvd that isnt a 1-click program, and i see that the rip from DVDfab is the problem.
    Video Sample:
    Picture Sample:
    RIP Information:
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom
    File size : 1.87 GiB
    Duration : 1h 1mn
    Overall bit rate : 4 194 Kbps
    Writing application : Lavf53.21.0
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : Main@L3.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 1 frame
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Duration : 1h 1mn
    Bit rate : 4 000 Kbps
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 25.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.174
    Stream size : 1.73 GiB (93%)
    Writing library : x264 core
    Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
    Transfer characteristics : BT.709-5, BT.1361
    Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
    Audio
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 3
    Mode : Joint stereo
    Mode extension : MS Stereo
    Codec ID : 6B
    Duration : 1h 1mn
    Bit rate mode : Constant
    Bit rate : 192 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Stream size : 142 MiB (7%)
    Writing library : LAMEªª€)›P
    Hi Yali
    CBR929
      Hello.
      I got no logs in that folder, the dvd rip completed to 100%.
      I dont know why this occurs and how to stop it.
        Hi Yali
        If it completed then you should have logs.
        Logs are created every time you open and use Fab.
        CBR929
