file to dvd problem
    file to dvd problem
    when I try to add a file to burn it doesn't work. Any suggestions? Thx
    Yes post the information listed in this link
    Once you have posted the info needed to this thread you will get help
      dvdfab_burn_vso.log
      Can not add files to burn in data mode when I browse. disc to disk no problem, Dell Dimension 8250, 2.8g, 512 ram, LG super multi burner, Sony dvd. HELP!
        You can't just add files. You must either select a DVD Structure folder or an ISO image.
        Fab is not a DVD Authoring package and you cannot create a DVD from other media files.
