I just bought a new computer and need to know how to transfer dvdfab over on the new one. Just how do I go about doing this? thanks 2boot
transfering dvdfab
Download the software from here install it and apply the key. You should remove it from the old one before it gets away from you. If you keep it just don't run both at the same time or risk getting blacklisted.How to post the internal log
