DVDFab Copy / Blank Media Timeout
    What is the timeout length when using DVDFab Copy when the "copy" task completes and it's waiting for the user to insert a blank disc for the "write" task step?
    I occasionally am seeing a problem where I assume the timeout expires and when I get to the PC to insert a blank disc, the "Waiting for blank media/not detected" msg dialog box is no longer being displayed.
    When the dialog box is no longer displayed (which I assume means that the timeout period expired), I can't proceed to the "write" task step so I have to repeat the "copy" task and start the same disc copy task again.
    I'm running DVDFab version 8.1.7.3
    Hi Scoop, why don't you set the target as your hard drive, that will complete without your input then you can use the "Write Data" function to burn the disk whenever you get around to it.
      Thanks for the suggestion I don't often use the "target to Hard Drive" option since I'm a basic DVDFab user but your idea works great for my current needs.
        You're welcome Scoop!
