What exactly is low to high? I noticed some blank Verbatim discs LTH being sold for a reasonable price.
Verbatim BD-R LTH (Low to High)
Low to High describes the change in reflectivity of the written surface of the disk. With LTH the laser changes the dye’s reflectivity from low to high rather than high to low. It is a more cost effective way to manufacture blanks. Most all recent drives will use them without issue. Check your firmware it may need to be updated.
bearlight,
I've been using the 2x's for about a year with no problems. However, they are getting hard to find so went to the 6x's. Bought 4 pks and they are horrible. The reviews are bad too. Went back to regular verb's(non LTH) at 6x and these are great, no problems so far (2 Months usage).
