How do locate movie temp.files
    I can easily check full or Main movie files after completing copy task using 8.0.8.5.
    I need directions to find movie files with the latest versions.
    My OS is Windows 7. My storage is 120gb SSD with about 50gb free after almost 2 years using temp. files.
    Sometimes I need to check because once in while the temp.file is not deleted.
    Look in Common Setting to see where your folders are.
    See attachment.
