Blu_ray burner
    Optical Drives Blu_ray burner
    Hi there,
    How do you know whether your blu-ray burner is dead? I have had no problem using my burner to copy and compress for a backup, but when I try to burn the blu-ray ISO, I get "Writing", and 0.03%, then the disc tray opens, and asks me if I want to burn again, failed. I try again, and get the same response.
    I tried to use the same burner and reversed my drives, and made a backup burn of a straight DVD, and no problem. So no issues burning a regular DVD, but issues burning a BLU-RAY.
    Is it possible, that the DVD burning works, but the BLU-RAY burning doesn't?? Do they have separate burners or lasers doing different work?
    I don't understand how they work, so I am totally baffled.
    Any help would be appreciated.
    Thanks.
    "Are you still master of your domain?"
    Cosmo Kramer
    Burning prob
    Try imgburn set write speed half of media
    ...Death Before Dishonor...
      Originally posted by dcc1048
      How do I do that????
      Is that a different burning software? I use 1 Click DVD Pro for my dvd's and works fine...
      Why are you asking questions on the DVDFab forum if you use other sofware to copy your movies.
      Thread closed.
        Your profane name calling PM to me has resulted in a 6 [six] month suspension for you.
