HD Decrypter
    HD Decrypter
    Ok. I used to use the Decrypter to rip my movies to the hard drive before converting them to the format that I want. Problem is that I told the start up window that gives all of the options to not show again. There's 2 solutions, so help me find one of them.
    1. how do I get that start up window back? I looked in all of the options and I can't find it.
    2. Show me where to go in the available options to from the main home screen to get to the decrypter.
    thanks.
    Open DVDFab.
    Click on BLUE question mark ? in upper right corner.
    Click on ABout.
    You should be able to see what you need now.
      If you want it to show every time you start up DVDFab you'll have to do a reinstall. That's the only way I've found it to work.
        Originally posted by Gruñón View Post
        Open DVDFab.
        Click on ABout.
