Can't get dvdfab 8.1.8.5qt to start
    I have been using dvdfab for years. I still have version 8.0.5.0 on my system, and it works just fine. When I click on the shortcut to DVDFab 8.1.8.5 qt the profile editor screen shows up announcing dvd fab for about 8 to 10 seconds then the welcome to DVDFab screen appears and indicates that DVD Copy and Blu-ray Copy are licensed to me, that they are indeed enabled, and Never Expire. When i then click on the Start DVDFab button lower right corner the normal run screen appears for about 2 seconds then disapears I have checked the Event Viewer, with the result that nothing has occurred. the specifications for my computer are listed below. thank you for any help.
    Blu-Ray recorder: Lite-On IHBS 112-29-2.
    DVD Recorder: ASUS 1680P
    RAM: 1333MHz DDR3 4GB
    CPU: AMD Phenom II 1090T BE 3.2Ghz 6 core
    Motherboard: ASUS M4A78T-E
    Video Card: Sapphire Radeon HD7770 GHZ 1Gb GDDR
    Display: W2253TQ LG Monitor
    Power Supply: 700 Watt Sea Sonic
    Operating System: Microsoft XP SP3 Home Edition
    Storage: 2, WD 80Gb SATA hard drives
    Used for operating system and operating system back-up.
    Plus: 1, 2TB WD Caviar green hard drive
    Used for all programs and data split into 4 virtual drives as follows:
    Downloads: 80.00GB
    Programs: 244.00GB
    Photos: 80.00GB
    Movies: 1.42TB
