trouble with 3D
    trouble with 3D
    I use Blu-Ray Copy to copy my Blu Ray to hard drive and it works. I can play it correctly with PowerDVD 12 fine. However if it's a 3D Blu-Ray, it copys but then PowerDVD 12 complains:
    "CyberLink PowerDVD could not read a file on the disc.
    Playback will stop."
    Note that if I play the Blu-Ray 3D disc directly (rather than from the hard drive copy) it plays correctly.
    So is the problem with PowerDVD or DVDFab? Regular Blu-Ray (not 3D) copy and play fine. I've tried these 2 3D Blu-Rays with the same results: "Tin Tin" & "Monsters vs Aliens".
    Are you mounting the MiniISO to play it?
      I allow it to create the MiniISO but that's all I do. Do I need to download and launch DVDFab Virtual Drive?
      Note that I'm not sure if you call this an ISO copy. I'm a bit confused by the terms. After it's done copying I have a full file structure, not just one big file.
        Yeah, I'd do that then mount the drive and try to play from there.
        It's not an ISO but that is what MiniISO/VD are for.
        I have seen problems reported with PowerDVD though and I understand that the developers are looking at it.
          Please do not copy the 3D Blu-ray disc "Tin Tin" to 25BD, since it is a very very special disc, and will make many problems. For others, are good support.
