Couldn't install 8.1.9.6
    Downloaded Version 8.1.9.6 last night and I couldn't install it. The Installation locked up twice.
    Hi SweetOne69
    Did you try to save the installer and then right click on it and run as administrator?
    CBR929
      I tried "Run as Administrator" last night and same result.
      This is odd as I've never had any problems before this.
        DVDFab8196Qt
        Get about halfway with the install then reports files are corrupted & install has to be aborted.
          8.1.9.7qtbeta installs without any problems
            I got it figured out. Something must of been running that interfered with the DVDFab installer. I rebooted the PC and I had no issues with the installation.
              Hi SweetOne69
              Glad you figured it out.
              CBR929
