DVD to BluRay?
    DVD to BluRay?
    Hi, I would like to find out if it's possible and if so, how, to burn DVDs to blu-ray.I have a series on DVD that would take up less space if I could put the series on blu-ray .I have the latest edition of DvdFab and I own the Blu-ray copy version.Thanks.
    Nope....
      Hi JAME5
      I may be wrong, but I believe that you would have to use Blu-ray Creator, and copy the movies to folders using DVD Copy on your Hdd, then use the Video TS folders to convert to burn to a Blu-ray disc.
      CBR929
        CBR, I am pretty sure that what will happen then is that the DVD's will be made BR Compliant and then they will be upscaled losing all space savings.
        Also, no menu editor as yet so how do you drive them?
        Hi JAME5
        CBR929
          Hey Greg
          I have not tried to do this, so I was unsure.
          True, maybe some day we will have menus.
          CBR929
