I need dual layer media what brand is good
    I tried backing up my Downton Abby DVD and it says it needs dual layger media. I need a fairy inexpensive kind any suggestions.
    Also If I copied it to my hard drive how do I go about putting it on a dvd?
    Hi Lenora
    Are you using the free or paid version of Fab???
    Please give more information e.g. full disc, main movie...
    The only DL media I ever suggest is Verbatim with the AZO dye on the package.
    I have answered your last question on your other thread.
    CBR929
      Verbatim and Ridata are probably the best 2 brands for DL discs.They are actually comparable in price to the more commonly found brands like Memorex .
      Does your computer have one drive or two, also does your burner accept DL discs? If your burner will burn dual layer discs, then you only need to change the disc type at the bottom of the burn screen from dvd5 to dvd9. If you can burn a DL disc, you can still burn the movie, either by compressing it, or splitting the burn onto 2 single layer discs.
