Using Beta & Registered Copy
    Ever since I registered my copy of DVD Fab I haven't downloaded and used any betas -- I just waited for the official release. However, I want to try out the new beta with "Safe" as I bought it last night after seeing the notification that the new beta would accomodate it.
    Can I use a beta and a registered copy at the same time or do I have to uninstall the registered copy and install the beta? And when there is a new official release will I have to uninstall the beta and install the new official release?
    No, it will install over your lastest version installed
      Hi Miami
      You should also save your installers of Fab in case you have problems with a newer version, you can always revert back to a older version or have multiple versions running at the same time.
      CBR929
        There are methods to install various versions of Fab on the one PC but let's not get into that unless it is necessary.
        I also find the terminology "BETA Release" incorrect. More correctly, I think it should be called a "Maintenance Release".
          That's true, I also did not want to confuse them with that process, I have 22 installed and running
          Very true my friend about the releases...
            Yeah, I find that people are understandably reluctant to install "BETA" software.
            Most of these so-called "BETA" releases are released because of new copy protection schema and are not really "BETA" releases.
