Optical drive down, looking for a replacement
    Optical Drives Optical drive down, looking for a replacement
    Hello group, my optical drive went down today. Fortunately, I had a backup optical drive. Does anybody have any good tips for hot buys, good internal DVD burners? I've seen a few on Newegg. One is loaded with features but I could do without the lightscribe. TIA
    SATA or PATA?
      Originally posted by Gummigutta View Post
      SATA or PATA?
      If from Newegg it would have to be Sata, they do not have any Pata internal drives for desktops.
      You do not have to install the software if you do not want to.
      If you go with the best rated ones they are $20-$25
