Running two drives
    Running two drives
    I know this has come up and I even found one forum entry that looked like it was fixed as a feature but it is not as far as I can see. I have two BlueRay drives and cutting 1400 DVDs. I like each instance of DVD COPY to start with its own Shortcut and point to a profile or configuration file (Like an .INI or .CFG). Then I can configure each instance to scan or use specific BR drive or set a third icon to come up with PathPlayer Disabled, I hope you see the logic.
    I don't want to start them with a command line parameter (even though that may do the job) BUT with a seperate Config file Sky is the limit.
    Also why DVDFAB GUI single threaded or behaves like that. When it is scanning the drive the GUI is Locked down. IF I manage to open the Target dialog box BEFORE it starts scaning then it works, otherwise have to wait for the scan to complete. We are all running Multi-threaded OSes so we should be able to access the GUI at all time
    Thanks for a great product. I could have easily used the FREE version but decided to pay as you have really earned it...
    OK Lots of people are watching but no one wants to answer !!!
    Can someone from DVDVFAB try and answer the first query??
