Can dvdFab
    Can dvdFab
    Does anyone know if DVDFab can write a DVD with a .DMG file?
    Don't know. What's a .DMG file? How is it produced? Is it a disk image file?
      It is a mac disc image file!
        I would have to say no then.
        Fab recognises .ini, .iso, ,img & nrg disk image files.
        You could always try renaming it to say an ISO file and give it a try.
          GregiBoy is correct...at least afaik.
          There is a freeware utility...DMG2ISO...that will convert a .DMG file to an .ISO file.
          I'm not sure if this will work, but it should.
          Worth a shot
            Thanks for the help! Now if someone could help with an annoying teenager;P
