I am having problems with Despicable Me and Tron Legacy (3D). I have tried two different new disc on both titles.The process starts OK on both movies but both stall at the same point on each movie. I am using version 8215. Log files are available if needed. If so should I copy and paste into this forum of attach and email. I will also provide any additional information I can to help. This is my first time to request assistance, so I'm unsure all that is needed.
Despicable Me & Tron Legacy
Here are the log files for the last attempt of both movies. (sfdchiefo)
Tron Legacy
DVDFab 8.2.1.5 (2012/10/31 19:08:37)
0m 01.63s: GPUAccelerate: 12351
0m 01.63s: CUDA cap: 1
0m 01.63s: Support coreavc decode: 0
0m 01.63s: Graphics info: NVIDIA GeForce GT 640 : 5.0 : 2.1
0m 01.66s: Qt Translator file load success
0m 01.77s: Load config successful.
0m 01.99s: Init profile data driver sucessful.
0m 03.80s: Init GPU settings sucessful.
0m 03.80s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2dvd 1 file2bluray 1 file2mobile 1 filemover 1
0m 03.80s: dvd2dvd:dvd2mobile:blu-ray2blu-ray:blu-ray2mobile:blu-ray23d:blu-ray2dvd:file2mobile:file2dvd:file2bluray:
0m 04.03s: Config ExBar successful.
0m 04.03s: dvd2dvd have 8 elements.
0m 04.12s: dvd2mobile have 31 elements.
0m 04.69s: blu-ray2blu-ray have 4 elements.
0m 04.71s: blu-ray2mobile have 20 elements.
0m 05.06s: blu-ray23d have 7 elements.
0m 05.20s: blu-ray2dvd have 1 elements.
0m 05.22s: file2mobile have 30 elements.
0m 05.76s: file2dvd have 1 elements.
0m 05.77s: file2bluray have 1 elements.
0m 06.01s: Config work ui controls successful.
0m 17.53s: Init burn engine successful.
0m 17.61s: StartNotify successful.
0m 29.10s: opening drive E
0m 29.10s: opened i/o
0m 29.10s: got media type 15
0m 29.46s: got disc type 0
0m 29.47s: got max lba 24405119
0m 30.18s: type Blu-ray BDMV
0m 30.18s: volume label TRON_LEGACY_3D
0m 30.26s: aacs 1 bd+ 0
0m 35.13s: got discinfo
0m 36.02s: got bdmv
0m 36.03s: Vendor: hp
0m 36.03s: Product: BD-RE BH38L
0m 36.04s: Revision: E64C
0m 36.04s: Vendor specific:
0m 36.04s: AACS version: 1
0m 36.04s: Number of concurrent AGIDs: 1
0m 36.04s: Supports bus encryption: YES
0m 36.05s: Supports binding nonce generation: YES
0m 36.05s: Supports Hybrid discs: NO
0m 36.05s: got agid 0
0m 36.06s: sent host cert chal
0m 36.07s: got drive cert chal
0m 36.07s: BEC 1
0m 36.07s: DRIVE_VENDOR 0x0073
0m 36.09s: got drive key
0m 37.13s: got host key signature
0m 37.13s: verified drive signature
0m 37.13s: verified host signature
0m 37.15s: sent host signature and key point
0m 37.15s: got bus key
0m 37.16s: got agid 0
0m 37.18s: sent host cert chal
0m 37.18s: got drive cert chal
0m 37.18s: BEC 1
0m 37.19s: DRIVE_VENDOR 0x0073
0m 37.21s: got drive key
0m 37.21s: got host key signature
0m 37.21s: verified drive signature
0m 37.21s: verified host signature
0m 37.23s: sent host signature and key point
0m 37.23s: got bus key
0m 37.23s: got volume id
0m 37.24s: got volume id mac
0m 37.24s: volume id is correct
0m 37.24s: got vid
0m 37.64s: blu-ray 389988E08AE635C18A49474DBEECBFD695A00C2F
0m 38.60s: cert BEE=0x00 same
0m 39.24s: D 7369671C
0m 39.24s: got vuk
0m 39.25s: got agid 0
0m 39.26s: sent host cert chal
0m 39.26s: got drive cert chal
0m 39.26s: BEC 1
0m 39.26s: DRIVE_VENDOR 0x0073
0m 39.28s: got drive key
0m 39.28s: got host key signature
0m 39.29s: verified drive signature
0m 39.29s: verified host signature
0m 39.31s: sent host signature and key point
0m 39.31s: got bus key
0m 39.31s: got data key
0m 39.31s: got unit key 1
0m 54.54s: stream(27,3,0)/clip(27,3,6) infos are not the same, using clip info to regulate it.
0m 55.57s: got extended bdinfo
0m 55.57s: opened blu-ray
1m 54.95s: Blu-ray Copy: Main Movie
1m 54.95s: Source: E:/BDMV/
1m 54.95s: Playlist: 70
1m 54.95s: Chapters: 1 -> 21
1m 54.95s: TotalSize: 44547 MB
1m 54.95s: SourceSize: 44547 MB
1m 54.95s: RemoveHDAudio: 0
1m 54.95s: CompressToAC3: 0
1m 54.95s: OutputSize: 46100 MB
1m 54.96s: OutputDisc: BDMV
1m 54.96s: OutputTarget: BD50
1m 54.96s: OutputVideo: 1080p/i
1m 54.96s: 3DMode: Blu-ray 3D
1m 54.96s: info: enable bd copy(mode=1)
1m 54.96s: info: streams(4113.1,4352.1,4353.1,4354.1)
1m 54.96s: info: blu-ray copy begin (unit[elem[atomic[00228.ssif],atomic[00226.ssif]]])
1m 54.96s: info: processing source(00228.ssif)
27m 19.49s: info: processing source(00226.ssif)
90m 12.27s: filter:503.28
90m 12.27s: filter:503.08
90m 12.27s: fifo:60ac-503.28-0-1,block:415
90m 12.27s: fifo:60ac-503.28-4-1,block:0
90m 12.28s: filter:505.08
90m 12.28s: fifo:60ac-503.08-0-6,block:0
90m 12.28s: fifo:60ac-503.28-1-2,block:3125
90m 12.28s: fifo:60ac-503.28-2-2,block:529
90m 12.28s: fifo:60ac-503.28-3-2,block:529
90m 15.26s: user cancelled
Despicable Me DVDFab 8.2.1.5 (2012/10/31 20:46:01)
0m 01.43s: GPUAccelerate: 12351
0m 01.43s: CUDA cap: 1
0m 01.43s: Support coreavc decode: 0
0m 01.43s: Graphics info: NVIDIA GeForce GT 640 : 5.0 : 2.1
0m 01.43s: Qt Translator file load success
0m 01.46s: Load config successful.
0m 01.58s: Init profile data driver sucessful.
0m 03.05s: Init GPU settings sucessful.
0m 03.05s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2dvd 1 file2bluray 1 file2mobile 1 filemover 1
0m 03.05s: dvd2dvd:dvd2mobile:blu-ray2blu-ray:blu-ray2mobile:blu-ray23d:blu-ray2dvd:file2mobile:file2dvd:file2bluray:
0m 03.21s: Config ExBar successful.
0m 03.21s: dvd2dvd have 8 elements.
0m 03.30s: dvd2mobile have 31 elements.
0m 03.85s: blu-ray2blu-ray have 4 elements.
0m 03.87s: blu-ray2mobile have 20 elements.
0m 04.23s: blu-ray23d have 7 elements.
0m 04.33s: blu-ray2dvd have 1 elements.
0m 04.35s: file2mobile have 30 elements.
0m 04.89s: file2dvd have 1 elements.
0m 04.91s: file2bluray have 1 elements.
0m 05.13s: Config work ui controls successful.
0m 09.27s: Init burn engine successful.
0m 09.34s: StartNotify successful.
0m 09.34s: opening drive E
0m 09.35s: opened i/o
0m 09.35s: got media type 15
0m 13.91s: got disc type 0
0m 13.91s: got max lba 24405119
0m 14.61s: type Blu-ray BDMV
0m 14.61s: volume label TRON_LEGACY_3D
0m 14.69s: opening drive E
0m 14.69s: opened i/o
0m 15.17s: got disc type 0
0m 15.18s: got max lba 24405119
0m 15.88s: aacs 1 bd+ 0
3m 41.82s: got discinfo
3m 41.82s: user cancelled
3m 41.82s: failed to open 1
4m 35.51s: opening drive E
4m 35.51s: opened i/o
4m 35.52s: got media type 15
4m 35.98s: got disc type 0
4m 35.99s: got max lba 23588223
4m 37.26s: type Blu-ray BDMV
4m 37.26s: volume label DESPICABLE_ME_3D
4m 37.29s: aacs 1 bd+ 0
4m 47.67s: Java protection is removed by StealthyClone anti-protection.
4m 47.76s: got discinfo
4m 47.92s: got bdmv
4m 47.93s: Vendor: hp
4m 47.93s: Product: BD-RE BH38L
4m 47.93s: Revision: E64C
4m 47.93s: Vendor specific:
4m 47.93s: AACS version: 1
4m 47.93s: Number of concurrent AGIDs: 1
4m 47.93s: Supports bus encryption: YES
4m 47.93s: Supports binding nonce generation: YES
4m 47.93s: Supports Hybrid discs: NO
4m 47.93s: got agid 0
4m 47.94s: sent host cert chal
4m 47.95s: got drive cert chal
4m 47.95s: BEC 1
4m 47.95s: DRIVE_VENDOR 0x0073
4m 47.97s: got drive key
4m 49.00s: got host key signature
4m 49.00s: verified drive signature
4m 49.01s: verified host signature
4m 49.03s: sent host signature and key point
4m 49.03s: got bus key
4m 49.04s: got agid 0
4m 49.05s: sent host cert chal
4m 49.06s: got drive cert chal
4m 49.06s: BEC 1
4m 49.06s: DRIVE_VENDOR 0x0073
4m 49.08s: got drive key
4m 49.08s: got host key signature
4m 49.08s: verified drive signature
4m 49.08s: verified host signature
4m 49.10s: sent host signature and key point
4m 49.10s: got bus key
4m 49.11s: got volume id
4m 49.11s: got volume id mac
4m 49.11s: volume id is correct
4m 49.11s: got vid
4m 49.22s: blu-ray 85D88DCF71643EF21D81F3B26F10D0B1E06AD7F4
4m 49.70s: cert BEE=0x00 same
4m 50.24s: D 80F49B9F
4m 50.25s: got vuk
4m 50.26s: got agid 0
4m 50.27s: sent host cert chal
4m 50.28s: got drive cert chal
4m 50.28s: BEC 1
4m 50.28s: DRIVE_VENDOR 0x0073
4m 50.30s: got drive key
4m 50.30s: got host key signature
4m 50.30s: verified drive signature
4m 50.30s: verified host signature
4m 50.32s: sent host signature and key point
4m 50.32s: got bus key
4m 50.32s: got data key
4m 50.33s: got unit key 7
5m 01.72s: got extended bdinfo
5m 01.72s: opened blu-ray
7m 37.53s: Blu-ray Copy: Main Movie
7m 37.53s: Source: E:/BDMV/
7m 37.53s: Playlist: 31
7m 37.53s: Chapters: 1 -> 21
7m 37.53s: TotalSize: 25867 MB
7m 37.54s: SourceSize: 24635 MB
7m 37.54s: RemoveHDAudio: 0
7m 37.54s: CompressToAC3: 0
7m 37.54s: OutputSize: 23000 MB
7m 37.54s: OutputDisc: BDMV
7m 37.54s: OutputTarget: BD25
7m 37.54s: OutputVideo: 1080p/i
7m 37.55s: 3DMode: Blu-ray 3D
7m 37.55s: info: enable bd copy(mode=1)
7m 37.55s: info: video encode mode(0), bitrate(28173), lr-encode(no)
7m 37.55s: info: streams(4113.2,4352.1,4355.1)
7m 37.55s: info: blu-ray copy begin (unit[elem[atomic[00028.ssif],atomic[00035.ssif]]])
7m 37.57s: info: h264_encode: encode param profile(2) level(41) bitrate(28173)
7m 37.61s: info: processing source(00028.ssif)
17m 39.16s: info: processing source(00035.ssif)
31m 15.52s: filter:503.14
31m 15.52s: fifo:605c-503.28-0-1,block:516
31m 15.52s: fifo:605c-503.28-3-1,block:0
31m 15.52s: filter:503.28
31m 15.53s: filter:503.19
31m 15.53s: fifo:605c-503.14-0-6,block:0
31m 15.53s: filter:505.08
31m 15.53s: fifo:605c-503.19-0-6,block:0
31m 15.53s: fifo:605c-503.28-1-2,block:4096
31m 15.54s: fifo:605c-503.28-2-2,block:699
31m 16.32s: info: group(elem[atomic[00028.ssif],atomic[00035.ssif]]) playtime(5688682 ms) source(25867 MB) request(22770 MB) real(3459 MB) bitrate(28173 kbps)
31m 16.34s: compress finished: groups request(22770 MB, 22770 MB) real(3459 MB) average_bitrate(28173 kbps)
31m 16.34s: user cancelledLast edited by sfdchiefo; 11-06-2012, 09:52 PM.
Have you filled out a support request here:How to post the internal log
Thank you for your response. Again, I am new to the forum. I have sent, through the software, an email that was provided after the errors occurred. That was a couple of weeks ago. I then posted on this forum for assistance, with no response. I will keep the link you provided and if I incur any other problems I will use this medium. Thank you again for your assistance.
This forum is a user helping other users based on experience forum. If no one in the user community has experienced the issue or knows how to resolve it you may not get a response. The developers do come here and offer expert advice regularly but I'm pretty sure don't see each and every post.How to post the internal log
Hi sfdchiefo
Please update to the latest version found here
If still having problems post your internal log for these movies using the latest version.
CBR929Even if it's a little thing, do something for those who have need of help, something for which you get no pay but the privilege of doing it.
