Currently running V.8.2.2.0 with Pathplayer enabled on XP Pro SP3.
Occasionally, say 5% of the time, DVDFab seems to get stuck when initially scanning a DVD. The drive light flashes a bit at first, but then I can hear that the disc has stopped spinning. The scanning progress bar just goes and goes... forever.
I've tried stopping DVDFab, having the disc in or out of the drive when starting the program, rebooting, installing an older version of the program, disabling av, etc. None of those things help.
I just tried running Passkey after rebooting and although that did not help DVDFab, I then ran DVDShrink and it was able to do the job. Then I tried again without Passkey helping and DVDShrink did not work. So that suggests to me that Passkey works better than DVDFab - but WHY
I thought it might be the drive, so I installed an old IDE one and it DID work for that particular disc, so I left it in plus the original drive which is SATA.
A few discs still have the endless scanning problem with both drives, it is puzzling. I've also checked the discs for scratches and fingerprints, but they are crystal-clear and play OK on an external DVD player.
