The last time I used DVDFab was 08-28-2012 according to the LOG. I tried to run DVDFab on 11/19/2012 and it would not longer run. I updated to a newer
version and tried that, same thing. I uninstalled all versions and updated to
DVDFab V9 and it also has the same problem.
Windows 7 machine with Intel E8500 Dual Core 3.16ghz processor and 4 gig of ram. Windows 7 is current all the way up to .NET V4.
Click on the icon for DVDFab and the little Windows 7 wait circling icon comes up and then goes away. I've been trying different options to no avail since 11-19-2012. Here is the DVDFab log since 08-28-2012.
Any help or info or system requirements notes would be greatly appreciated.
DVDFab 8.2.0.0 (2012/08/28 18:50:01)
0m 01.08s: GPUAccelerate: 3
0m 01.08s: CUDA cap: 0
0m 01.09s: Support coreavc decode: 0
0m 01.09s: Graphics info: ATI Radeon HD 3600 Series : :
0m 01.09s: Qt Translator file load success
0m 01.12s: Load config successful.
0m 01.12s: Init profile data driver sucessful.
0m 03.16s: Init GPU settings sucessful.
0m 03.16s: option dvd2dvd 1 dvd2mobile 0 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2dvd 1 file2bluray 1 file2mobile 0 filemover 0
0m 03.17s: dvd2dvd:dvd2mobile:blu-ray2blu-ray:blu-ray2mobile:blu-ray23d:blu-ray2dvd:file2mobile:file2dvd:file2bluray:
0m 03.39s: Config ExBar successful.
0m 03.39s: dvd2dvd have 8 elements.
0m 03.54s: dvd2mobile have 31 elements.
0m 03.54s: blu-ray2blu-ray have 4 elements.
0m 03.56s: blu-ray2mobile have 20 elements.
0m 04.10s: blu-ray23d have 7 elements.
0m 04.26s: blu-ray2dvd have 1 elements.
0m 04.29s: file2mobile have 30 elements.
0m 04.30s: file2dvd have 1 elements.
0m 04.32s: file2bluray have 1 elements.
0m 04.51s: Config work ui controls successful.
0m 11.58s: Init burn engine successful.
0m 11.64s: StartNotify successful.
0m 11.66s: opening drive H
0m 11.67s: got media type 15
0m 12.17s: got max lba 22615583
0m 13.33s: type Blu-ray BDMV
0m 13.35s: volume label LIMITLESS_BD
0m 14.55s: aacs 1 bd+ 0
0m 23.15s: Java protection is removed by StealthyClone anti-protection.
0m 23.23s: got discinfo
0m 33.54s: got bdmv
0m 33.54s: Vendor: ATAPI
0m 33.56s: Product: iHBS212 2
0m 33.56s: Revision: 5L09
0m 33.56s: Vendor specific: 2011/02/23 14:18
0m 33.56s: AACS version: 1
0m 33.56s: Number of concurrent AGIDs: 2
0m 33.56s: Supports bus encryption: NO
0m 33.56s: Supports binding nonce generation: NO
0m 33.56s: Supports Hybrid discs: NO
0m 33.56s: got agid 0
0m 33.62s: sent host cert chal
0m 33.62s: got drive cert chal
0m 33.62s: BEC 0
0m 33.62s: DRIVE_VENDOR 0x0128
0m 33.70s: got drive key
0m 34.16s: got host key signature
0m 34.17s: verified drive signature
0m 34.17s: verified host signature
0m 34.24s: sent host signature and key point
0m 34.25s: got bus key
0m 34.25s: got agid 0
0m 34.31s: sent host cert chal
0m 34.32s: got drive cert chal
0m 34.32s: BEC 0
0m 34.32s: DRIVE_VENDOR 0x0128
0m 34.40s: got drive key
0m 34.40s: got host key signature
0m 34.40s: verified drive signature
0m 34.40s: verified host signature
0m 34.48s: sent host signature and key point
0m 34.48s: got bus key
0m 36.61s: got volume id
0m 36.61s: got volume id mac
0m 36.61s: volume id is correct
0m 36.61s: got vid
0m 36.86s: blu-ray 7BB4876BB9CD1EEE9C1592504EE0A0FFBF7181B9
0m 37.41s: cert BEE=0x00 same
0m 37.60s: D DA87B9FC
0m 37.60s: got vuk
0m 37.94s: got unit key 1
1m 08.10s: got extended bdinfo
1m 08.10s: opened blu-ray
1m 38.99s: WorkAttr::Init Start
1m 39.04s: WorkAttr::Init OK: m2ts.passthrough
2m 05.36s:
2m 05.38s: info: create config(5)
2m 05.38s: info: convert profile(m2ts.passthrough)
2m 05.38s: info: bluray playlist(2),angle(0),chapter(1->25),3D(0)
2m 05.38s: info: streams((4113.1)(4352.1)(4608.1))
2m 05.38s: info: subpicture preset(4), mode(4)
2m 05.39s: info: processing source(00000.m2ts)
3m 27.64s: info: processing source(00052.m2ts)
3m 44.46s: info: processing source(00029.m2ts)
5m 13.55s: info: processing source(00053.m2ts)
5m 41.17s: info: processing source(00031.m2ts)
6m 00.08s: info: processing source(00054.m2ts)
6m 06.77s: info: processing source(00033.m2ts)
8m 50.27s: info: processing source(00055.m2ts)
9m 03.52s: info: processing source(00035.m2ts)
9m 34.26s: info: processing source(00056.m2ts)
9m 45.87s: info: processing source(00037.m2ts)
10m 20.03s: info: processing source(00057.m2ts)
10m 29.91s: info: processing source(00039.m2ts)
11m 36.72s: info: processing source(00058.m2ts)
12m 12.87s: info: processing source(00041.m2ts)
14m 34.00s: info: processing source(00059.m2ts)
14m 46.54s: info: processing source(00043.m2ts)
15m 11.91s: info: processing source(00060.m2ts)
15m 36.87s: info: processing source(00045.m2ts)
16m 30.32s: info: processing source(00061.m2ts)
16m 36.62s: info: processing source(00047.m2ts)
17m 16.79s: info: processing source(00062.m2ts)
17m 23.64s: info: processing source(00049.m2ts)
18m 10.33s: info: processing source(00063.m2ts)
18m 38.51s: info: processing source(00050.m2ts)
21m 27.21s:
------ finish mobile work ------
DVDFab 8.2.2.0 (2012/11/19 18:03:59)
DVDFab 8.2.2.0 (2012/11/19 18:04:59)
DVDFab 8.2.2.0 (2012/11/19 18:05:10)
DVDFab 8.2.2.0 (2012/11/19 18:05:27)
DVDFab 8.2.2.0 (2012/11/19 18:05:47)
DVDFab 8.2.2.0 (2012/11/19 18:06:28)
DVDFab 8.2.2.0 (2012/11/19 18:07:13)
DVDFab 8.2.2.0 (2012/11/19 18:07:14)
DVDFab 8.2.2.0 (2012/11/19 18:07:16)
DVDFab 8.2.2.0 (2012/11/19 18:07:18)
DVDFab 8.2.2.0 (2012/11/19 18:07:19)
DVDFab 8.2.2.0 (2012/11/19 18:07:21)
DVDFab 8.2.2.0 (2012/11/19 18:07:22)
DVDFab 8.2.2.0 (2012/11/19 18:08:58)
DVDFab 8.2.2.0 (2012/11/19 18:10:09)
DVDFab 8.2.2.0 (2012/11/19 18:17:16)
DVDFab 8.2.2.0 (2012/11/19 18:17:51)
DVDFab 8.2.2.0 (2012/11/21 19:36:07)
DVDFab 8.2.2.0 (2012/11/21 19:37:17)
DVDFab 9.0.1.0 (2012/11/21 19:40:07)
DVDFab 9.0.1.0 (2012/11/21 19:47:47)
DVDFab 9.0.1.0 (2012/11/21 19:48:23)
DVDFab 9.0.1.0 (2012/11/21 19:53:01)
DVDFab 9.0.1.0 (2012/11/21 19:59:07)
DVDFab 8.2.0.0 (2012/11/21 20:00:41)
DVDFab 8.2.0.0 (2012/11/21 20:00:52)
DVDFab 8.2.0.0 (2012/11/22 16:00:12)
DVDFab 9.0.1.0 (2012/11/22 16:05:34)
DVDFab 9.0.1.0 (2012/11/22 16:05:53)
0m 33.54s: got bdmv
0m 33.62s: BEC 0
0m 34.32s: BEC 0
0m 36.61s: got vid
0m 37.60s: got vuk
2m 05.36s:
21m 27.21s:
