Here is the log and another log says failed to detect media which is Verbatim + R and yes it's the ones with the AZO dye
DVDFab 9.0.1.1 (2012/11/24 08:59:46)
0m 00.43s: GPUAccelerate: 0
0m 00.43s: CUDA cap: 0
0m 00.43s: Support coreavc decode: 0
0m 00.45s: Graphics info: NVIDIA GeForce 6200 : :
0m 00.45s: Qt Translator file load success
0m 00.50s: Start get sys number.
0m 00.50s: Serial number is: 00-0e-a6-1d-4f-5e
0m 00.50s: Reg URL link is:
0m 00.50s: Version is: 9011
0m 00.50s: Product is: 2
0m 00.51s: Connect type is: 0
0m 01.78s: Times of connecting error is: 0
0m 01.78s: Parse string is: 2:8260762964
0m 01.78s: Parse string is: 11:8260762964
0m 01.79s: Parse string is: OV:9011
0m 01.79s: Parse string is: BV:9008
0m 01.79s: Parse string is: S:9674847f000ce806b7502fbd7c57f7a1
0m 02.00s: End check info.
0m 02.00s: Load config successful.
0m 02.07s: Init profile data driver sucessful.
0m 02.40s: Init GPU settings sucessful.
0m 02.40s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2dvd 1 file2bluray 1 file2mobile 1 filemover 1
0m 02.42s: dvd2dvd:dvd2mobile:blu-ray2blu-ray:blu-ray2mobile:blu-ray23d:blu-ray2dvd:file2mobile:file2dvd:file2bluray:
0m 14.56s: Init burn engine successful.
0m 50.68s: opening drive D
0m 50.68s: opened i/o
0m 50.70s: got media type 4
0m 50.90s: got disc type 10
0m 50.90s: got max lba 2285999
0m 50.98s: type DVD-VIDEO
0m 50.98s: volume label DVD
0m 51.29s: failed to read disc key: sensekey 00 asc 00 acsq 00
0m 51.53s: failed to read disc key: sensekey 00 asc 00 acsq 00
0m 51.75s: failed to read disc key: sensekey 00 asc 00 acsq 00
0m 51.95s: got copyright 0 0
0m 52.50s: got udf/iso
0m 57.57s: got discinfo
0m 57.60s: pathplayer disabled 0
0m 58.68s: got dvdinfo
0m 58.89s: opened dvd
2m 45.40s: opening drive D
2m 45.40s: opened i/o
2m 45.42s: got media type 4
2m 46.09s: got disc type 10
2m 46.09s: got max lba 2285999
2m 46.18s: type DVD-VIDEO
2m 46.18s: volume label DVD
2m 46.20s: opening drive E
2m 46.29s: opened i/o
2m 46.29s: failed to detect media type
2m 46.31s: got disc type 0
2m 46.31s: got max lba 0
4m 21.37s: opening drive E
4m 21.51s: opened i/o
4m 21.51s: got media type 12
4m 21.53s: got disc type 0
4m 21.53s: got max lba 0
4m 25.59s: terminate process
